Hello,
Would any one have the specs for an Harman & Collins SU-6015 camshaft? Thanks in advance. -Gabe Naccarato |
IO - 26B, IC-64A, EO-59B, EC-19A. 270* duration on intake, 258* on exhaust. 45* overlap and .320 lift on both. Clearance: .011 intake and .013 exhaust
Latta cam for the street, might sound good tho!!!
Gramps |
Thanks for the response guys! Would you consider this a full race or 3/4 race cam? Sorry I'm new to engine building, especially with the flathead! Thanks-Gabe
I had that cam in my sedan. 255” motor, 4” crank with 2x2. Ran great sounded amazing but not a ton of low end. I’ll try to post a video if I can figure it out…
**edit** my apologies! I miss read your question and you were asking about the 6015 cam- my post was for the 6014 cam. There is a video below anyway! IMG_2156.jpg IMG_2155.jpg
1932 2 door sedan/ Merc Flathead 1932 5W 1932 Roadster/ SCoT Flathead 1932 Roadster Cadillac power Last edited by birdball; 01-16-2025 at 07:59 PM. |
https://youtube.com/shorts/erb_9JDdi0g?feature=shared
1932 2 door sedan/ Merc Flathead 1932 5W 1932 Roadster/ SCoT Flathead 1932 Roadster Cadillac power |
Sounds good.
So much depends on what your engine is. A cam will tend to be a lot tamer in a 276" engine as opposed to a 239".
#9 | |
#10 | |
Thanks Gabe |
That is a lot of overlap for not much lift. I expect a cam with equal duration but a lot more lift would make more power, and idle about the same. Or you could get a cam with the same lift but less duration and get similar power but a nicer idle.
