Old 10-02-2022, 04:21 PM   #1
Weirdo
Default 1940-41 Ford pickup wooden cab mounts.
Hello all. I’m working on a 40 Ford pickup. I was wondering if anyone had drawings or measurements for the wooden cab mounts. I’ve seen lots on the web to buy, but since I’m this far in, I would prefer to make my own. I believe the only years are 40-41 that will work. Thanks.
Weirdo is offline   Reply With Quote
Old 10-02-2022, 05:31 PM   #2
Karl Wescott
Karl Wescott's Avatar
Default Re: 1940-41 Ford pickup wooden cab mounts.
FWIW, Ford made a floor design change sometime between the first 1938 and the last 1939. The 1940-41 blocks are the same as the later style.
Functionally, you likely do not need the full timber block Ford used. A short (about 4" front to back) spacer for the #2 and # 3 body bolts with a spacer covering between the # 4 body mount and front bed mount (the front bed mount timbers stack onto a "tail" of the body block" should do the job. Note the #1 cab bolt is direct to frame (except for a single layer of webbing).
Karl Wescott is offline   Reply With Quote
Old 10-03-2022, 07:04 AM   #3
Weirdo
Thanks for the information Karl. I would prefer to make it as original as possible. So the ford ones would be my preference. I’ll keep looking
Steve
Old 10-05-2022, 10:30 PM   #4
kirkf
kirkf's Avatar
I would like to see the dimensions for the box wood mounts as well, if you come across anything be sure to post it on here.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 10-06-2022, 08:19 AM   #5
Cecil/WV
Cecil/WV's Avatar
I have photos, but no dimensions.
Cecil/WV is offline   Reply With Quote
Old 10-06-2022, 09:04 AM   #6
Doublepumper
Doublepumper's Avatar
https://www.horkeyswoodandparts.com/...#fordcabblocks
Ever stop to think and forget to start again?
Doublepumper is offline   Reply With Quote
Old 01-05-2025, 09:36 AM   #7
Weirdo
I finally made some with my father in law.
Old 01-05-2025, 10:00 AM   #8
Karl Wescott
Nice!
btw, what is your father in law doing for legs now?
Old 01-05-2025, 10:36 AM   #9
Zeke3
Zeke3's Avatar
Thanks Karl, made me laugh. Those do look very nicely done.
Zeke3 is online now   Reply With Quote
Old 01-06-2025, 09:08 AM   #10
rustynut4247
rustynut4247's Avatar
i still make the right wood blocks with finger joints in ash although the oringnal were hard maple . ihave sold very many over the years . we were the first ones to make them correcty there is a tail piece missing in your picture
rustynut4247 is offline   Reply With Quote
Old 01-06-2025, 10:47 AM   #11
pistonbroke
Yes, the cab mount also is the loer part of the bed front mounts. Tim
Old 01-06-2025, 05:41 PM   #12
kirkf
kirkf's Avatar
I was just going to say, that the pickup cab wood should have an extended piece that goes under the first wooden cross member of the box.
You can see it in these pictures I found on the internet.
I don't have pieces like this. Bob Drake no longer sells them.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
Old 01-06-2025, 07:00 PM   #13
Mart
Mart's Avatar
Nice job, Weirdo. I made some too, based on some originals. Yours came out much better than mine. My originals and my copies also do not have the tails.
Old 01-09-2025, 01:48 PM   #14
Weirdo
I’ll have to go look at the rear of the truck. It’s still on the old frame.i knew there was a couple pieces left, but miss that tail. Should be a lot easier than the others
Old 01-09-2025, 02:52 PM   #15
38bill
38bill's Avatar
For reference these are the original "long" blocks that were under my '38 cab. They measure 61-1/2" long.
38bill is offline   Reply With Quote
Old 01-09-2025, 03:26 PM   #16
Karl Wescott
Bill, your blocks illustrate the "tail" perfectly. Note the differences between the 1938 blocks and the 1940-41 blocks where they fit the cab. This is due to the first 1938 carrying over the 1935-37 cab floor, and the redesign of the floor sometime before the last 1939.
Old 01-09-2025, 08:04 PM   #17
kirkf
kirkf's Avatar
I guess the real question is since only the trucks have cab wood, why is it that all the wood kits are incorrect and missing the tail piece?
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
Old 01-10-2025, 08:48 AM   #18
Karl Wescott
The good "expensive" repro's will have the tails. The "el cheapo" may not. Note that the OP had made his own in an admirable effort as these are not easy parts to make. I suspect the OP's will end up growing tails.
Old 01-12-2025, 11:20 AM   #19
TomT/Williamsburg
TomT/Williamsburg's Avatar
What I would like to see made are mounting blocks for the later 42-47 cabs on a 35-41 truck frames. Just a thought as I had yo jump through some hoops when buikding my wife’s truck …. the 43-47 cab was placed on a 36 frame ….
TomT/Williamsburg is offline   Reply With Quote
Old 01-13-2025, 12:37 PM   #20
kirkf
kirkf's Avatar
Yep the OP did a nice job on his wood, sadly I have zero wood skills!
There aren't many sources for truck wood at this point. Bob Drake at one point had all the pieces for the pickup, including cab wood, box cross pieces and all the long bolts etc. However now they carry nothing at all.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
