Old 11-27-2024, 03:01 PM   #1
deuce lover
deuce lover's Avatar
Default Deuce tudor pic & 16 "adj spoke wheels
Thought I'd share this pic of this 32 V8 std tudor off the auction site and notice the 2 pc adj spoke 16" wheels. There is a wheel like them also on the auction site.I believe they were Firestone acc wheels. RH tailite on the car also.
Happy Thanksgiving to all tho not celebrated here.
Old 11-27-2024, 03:41 PM   #2
alchemy
alchemy's Avatar
Default Re: Deuce tudor pic & 16 "adj spoke wheels
Yes, Firestones. Very rare nowadays. Even K-H adjustables are rare nowadays.
alchemy is offline   Reply With Quote
Old 11-27-2024, 04:32 PM   #3
deuce lover
Thanks for the confirmation on the wheels.
Old 11-27-2024, 07:31 PM   #4
cas3
Is the lock ring on the inside? I've only had one inside lock ring, an 18" cast hub that nobody was ever able to identify. Motor wheel we thought...Its gone now from my auction
Old 11-27-2024, 08:01 PM   #5
GB SISSON
GB SISSON's Avatar
I like the look they give that tudor.
Old 11-28-2024, 01:21 AM   #6
deuce lover
Yes on the inside with a notch on the inner edge and locks in place on the rim when tube is inflated in the tire.I had a pair of artillery wheels with a similar system.The lock ring had 2 "C" notches for easy removal so tire and tube would slip onto the rim.
Old 11-28-2024, 01:45 AM   #7
Brian
Brian's Avatar
There is a problem with the design of those Firestone wheels; the outer flange on the hub does not seat on the brakedrum like proper Ford wire wheels do...this leads to the wheel flexing, ultimately causing the area around the lug holes to crack.
Old 11-28-2024, 04:40 AM   #8
deuce lover
Brian,Here is a pic of the back surface.It should sit correctly on a 32-35 drum since they(the drums) have the necessary support tab built in.
Old 11-28-2024, 10:09 AM   #9
Brian
Brian's Avatar
'Should', but they don't! Mount one on a drum and you'll see what I mean, you'll be able to insert about a 1/8" feeler gauge around that outer lip.
Old 11-28-2024, 10:56 AM   #10
deuce lover
Brian,I was just showing what a Firestone wheel was and on a Deuce sedan.I don't any or plan on having any.
