Old 11-17-2024, 03:20 PM   #1
flathead34
flathead34's Avatar
Default Wet cock removal help needed
Went to winterize the '35. The pet cocks would not turn, they were frozen. Started to remove one pet cock from the block but I could not remove it due to interference with the front cross member. I could not get it out. Have any of you guys had a similar problem in removing them? Any help or suggestions
would be appreciated. Thanks Mike
flathead34 is offline   Reply With Quote
Old 11-17-2024, 04:06 PM   #2
Graeme / New Zealand
Graeme / New Zealand's Avatar
Default Re: Wet cock removal help needed
Was a bit worried when I saw your header for this post. Whew !......... I'm glad the text has clarified it.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 11-17-2024, 04:19 PM   #3
drolston
drolston's Avatar
Maybe loosen both front motor mounts (a lot) and jack up the engine far enough to get clearance for the petcock to turn. To avoid the risk of wringing off the brass petcock, I would drain and flush the radiator and put in the proper mix of anti-freeze.
Old 11-17-2024, 04:35 PM   #4
J Franklin
J Franklin's Avatar
Did you try to turn it with a pair of pliers? Sometimes they get sticky.
Old 11-17-2024, 05:06 PM   #5
Model51
Model51's Avatar
The petcock is made with a two piece brass friction fit tapered bore. That's why they can be stuck and hard to turn to open . If it's impossible to remove the petcock from the block then you can just do the flush as drolston suggested and leave the petcock in place.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 11-17-2024, 05:55 PM   #6
flathead34
flathead34's Avatar
yes. it would not turn
Old 11-17-2024, 07:45 PM   #7
19Fordy
19Fordy's Avatar
Can you apply heat to it?
Old 11-17-2024, 09:17 PM   #8
Bored&Stroked
Bored&Stroked's Avatar
Boy, that was a Hell of a post title! LOL
Old 11-17-2024, 10:39 PM   #9
3twinridges
3twinridges's Avatar
Good one 😬!
3twinridges is offline   Reply With Quote
Old 11-17-2024, 11:04 PM   #10
T Scott
GB
Good one Graeme!!!
T Scott is offline   Reply With Quote
Old 11-18-2024, 05:13 AM   #11
69a
Can you post a picture?
69a is offline   Reply With Quote
Old 11-18-2024, 10:07 AM   #12
Tim Ayers
Originally Posted by T Scott View Post
Good one Graeme!!!
LOL!!!!!!! Heat is your friend in both situations
Old 11-19-2024, 07:11 AM   #13
Model51
Model51's Avatar
flathead34
If you want the petcock to work, it's probably best to remove it, disassemble and clean it. Heat may not help as the corrosion preventing it from turning is an oxide of brass on both parts and doesn't quite react the same way as iron oxide does to heat.
Also, be careful when you try to remove it from the block. The section of the valve which goes into the block is hollow and your are going to be fighting brass-iron corrosion. If it shears off, then you have a much bigger project on your hands.
