Old 10-24-2024, 06:58 PM   #1
Ford46
Ford46's Avatar
Default 49 Ford F-1 PU Fuel Gauge Question
1949 Ford F-1 PU
Replaced fuel gauge and sending unit with new Bob Drake units.
Note: The gauge cluster and tank are grounded.
After replacement of both gauge did not work at all.
Removed Drake unit and reinstalled original sending unit
- gauge works, however, pulsates/fluctuates between Full and Half Tank reading
I'm posting for a friend and he is seeking any assistance or thoughts on this matter. Thank you in advance. LouB.
Ford46 is offline   Reply With Quote
Old 10-26-2024, 07:06 PM   #2
FortyNiner
FortyNiner's Avatar
Default Re: 49 Ford F-1 PU Fuel Gauge Question
With fuel gauges and sending units, it is often easier to troubleshoot before fully installing the sender. Check the connections - both signal and power.
Old 10-27-2024, 10:18 AM   #3
TJ
TJ's Avatar
Put an extra ground wire on one of the screws of the sending unit to see if that helps.
Old 10-27-2024, 11:01 AM   #4
19Fordy
19Fordy's Avatar
Ford46: Hopefully your friend still has the OEM KS Gas Tank Sending unit.
If so, this thread will be very helpful, especially post #3.
https://www.fordbarn.com/forum/showt...k+sending+unit
