Old 10-13-2023, 01:18 PM   #1
AL in NY
AL in NY's Avatar
Default Stipe Machine/Specialty Motor Cams
Is Stipe Machine/Specialty Motor Cams still in business? Their phone number and website are not working.
AL in NY
AL in NY is offline   Reply With Quote
Old 10-14-2023, 07:19 AM   #2
Ray in La Mesa
Default Re: Stipe Machine/Specialty Motor Cams
Thread on the other site said they are in the process of moving to Kentucky.
Ray in La Mesa is offline   Reply With Quote
Old 04-17-2024, 03:10 AM   #3
TomInCologne
TomInCologne's Avatar
sorry for the thread resurrection, but their website is not available...
Does anybody know any more?
TomInCologne is offline   Reply With Quote
Old 04-17-2024, 11:46 AM   #4
Jim Brierley
Try [email protected]
Old 04-17-2024, 07:33 PM   #5
acchaplin
Originally Posted by Jim Brierley View Post
Do you happen to have a currant phone #, please?
acchaplin is offline   Reply With Quote
Old 04-18-2024, 11:08 AM   #6
Jim Brierley
sorry, I don't.
Old 04-19-2024, 02:12 AM   #7
Dodge
I had been corresponding with Stipes since Jan. of 2023 about a camshaft. I was
on the waiting list and had been getting updates from them.
Then all of a sudden they went radio silent in June of 2023.
No answer to emails.
The latest email I have is: [email protected]
There has been problems getting cam cores for many different makes of engine after
COVID. I have a friend that was getting so tired of it that he has gone into the cam
core business. We just received two from him, one a small block Ford and the other a
Big Block Chevy.
We are doing a cad cam drawing of the Model A cam to see what its going to take to make cam cores. They would be a steel billet.
Dodge is offline   Reply With Quote
Old 04-19-2024, 06:16 AM   #8
springerpete
springerpete's Avatar
I got my Stipe shocks 2 years ago. Visited the shop in Plymouth, WI. I know there are lots of Model A'ers in WI and perhaps someone could stop at the shop for a look. Close by would be Manitowoc, Sheboygan, Fond du Lac, Two Rivers, Kohler, Port Washington, Kiel etc. Be a nice A ride as well. Bill
springerpete is offline   Reply With Quote
Old 04-19-2024, 07:15 AM   #9
nkaminar
nkaminar's Avatar
Dodge, If you make cam cores, make them with 5 bearings. That way they will work in the Burtz block. Not that the 3 bearing cams will not work but that the 5 bearing cams take advantage of the 5 journals.
Time has a way of changing things. Companies go in and out of business. What was available a few years ago have disappeared from the planet. If you like something and have the money for it, buy it now.
Old 04-19-2024, 07:50 AM   #10
johnneilson
The blanks are not hard to make
The drive gear is a little tricky but not impossible
The biggest challenge is getting the basic profiles for the lobes done, heat treated and final finish.
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 04-19-2024, 09:12 PM   #11
Krylon32
For Model A shocks I know they're not a stock shock but the Roto Shim lever shocks made in England are a great product.They have bolt on lever shocks that go right on a Model A or 32. They are accurate in size and unless your going for a high end restoration they are perfect. Check rotoshim.com Beats chasing Stipes. I'm not an A guy but Miller High Speed Heads seems to do a lot with A motors.
Krylon32 is offline   Reply With Quote
Old 04-20-2024, 01:04 AM   #12
J Franklin
J Franklin's Avatar
Roto shim lever shocks FYI: https://rotoshim.com/technical
J Franklin is online now   Reply With Quote
Old 04-21-2024, 12:47 PM   #13
Jim Brierley
Bill can sometimes be found on Facebook.
Old 04-22-2024, 10:50 AM   #14
Hotrodfil
Hotrodfil's Avatar
I'm on my third set of Rotoshim shocks. Because I now have them on all my cars...
Couldn't recommend them more highly.
Hotrodfil is offline   Reply With Quote
