Stipe Machine/Specialty Motor Cams Is Stipe Machine/Specialty Motor Cams still in business? Their phone number and website are not working.
Re: Stipe Machine/Specialty Motor Cams Thread on the other site said they are in the process of moving to Kentucky.
Re: Stipe Machine/Specialty Motor Cams Quote:
sorry for the thread resurrection, but their website is not available... Does anybody know any more? |
Re: Stipe Machine/Specialty Motor Cams |
Re: Stipe Machine/Specialty Motor Cams sorry, I don't.
Re: Stipe Machine/Specialty Motor Cams I had been corresponding with Stipes since Jan. of 2023 about a camshaft. I was
on the waiting list and had been getting updates from them. Then all of a sudden they went radio silent in June of 2023. No answer to emails. The latest email I have is: [email protected] There has been problems getting cam cores for many different makes of engine after COVID. I have a friend that was getting so tired of it that he has gone into the cam core business. We just received two from him, one a small block Ford and the other a Big Block Chevy. We are doing a cad cam drawing of the Model A cam to see what its going to take to make cam cores. They would be a steel billet. |
Re: Stipe Machine/Specialty Motor Cams I got my Stipe shocks 2 years ago. Visited the shop in Plymouth, WI. I know there are lots of Model A'ers in WI and perhaps someone could stop at the shop for a look. Close by would be Manitowoc, Sheboygan, Fond du Lac, Two Rivers, Kohler, Port Washington, Kiel etc. Be a nice A ride as well. Bill
Re: Stipe Machine/Specialty Motor Cams Dodge, If you make cam cores, make them with 5 bearings. That way they will work in the Burtz block. Not that the 3 bearing cams will not work but that the 5 bearing cams take advantage of the 5 journals.
Time has a way of changing things. Companies go in and out of business. What was available a few years ago have disappeared from the planet. If you like something and have the money for it, buy it now. |
Re: Stipe Machine/Specialty Motor Cams 1 Attachment(s)
The blanks are not hard to make
The drive gear is a little tricky but not impossible The biggest challenge is getting the basic profiles for the lobes done, heat treated and final finish. J |
Re: Stipe Machine/Specialty Motor Cams For Model A shocks I know they're not a stock shock but the Roto Shim lever shocks made in England are a great product.They have bolt on lever shocks that go right on a Model A or 32. They are accurate in size and unless your going for a high end restoration they are perfect. Check rotoshim.com Beats chasing Stipes. I'm not an A guy but Miller High Speed Heads seems to do a lot with A motors.
Re: Stipe Machine/Specialty Motor Cams Roto shim lever shocks FYI: https://rotoshim.com/technical
Re: Stipe Machine/Specialty Motor Cams Bill can sometimes be found on Facebook.
Re: Stipe Machine/Specialty Motor Cams I'm on my third set of Rotoshim shocks. Because I now have them on all my cars...
Couldn't recommend them more highly. https://img.retro-rides.org/i/v/hotr...8011a68746.jpg |
| All times are GMT -5. The time now is 06:45 AM. |
