Old 09-02-2023, 03:32 PM   #1
ted55ford
ted55ford's Avatar
Default Replacing the back deck on my 55 Fairlane.
Hi All,
I need advice on how to replace the back deck,,,what kind of material did you use?....Cardboard or perhaps particleboard?...Thanks in advance.....Ted.
File Type: jpg 372150955_6944920082185514_4039820912931215036_n.jpg (42.2 KB, 23 views)
1955 FORD FAIRLANE
1967 FORD MUSTANG CONV.
ted55ford is offline   Reply With Quote
Old 09-02-2023, 04:24 PM   #2
JeffB2
JeffB2's Avatar
Default Re: Replacing the back deck on my 55 Fairlane.
OR DIY
Originally Posted by ted55ford View Post
Hi All,
Premade available here. https://collectorsautosupply.com/pac...ainline-sedan/ Or DIY https://www.youtube.com/results?sear...y+installation
JeffB2 is offline   Reply With Quote
Old 09-03-2023, 02:56 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
Many of the resto parts suppliers sell pre-cut heavy cardboard package tray, custom fit for your model. You can order them in original colors or dye the cardboard with the color of your choice. Mac's and Concours have offered them, but possibly others too.
I actually cut up a tall cardboard shipping carton and glued crushed vinyl matching my seats and door panel upholstery. Lay it on the structural support under the back window and go underneath to poke the two holes for the hold-down buttons.
Old 09-11-2023, 11:07 PM   #4
Abe Lugo
Find an upholstery supply and get the door panel board but in the larger size.
Maybe a template from the old one. Transfer the outline to you new cardboard. Cut it to size. Then find some fabric that you want to use. Usually you can overlap it about 2 inches. The. Cut some notches so the fabric can roll over the edge. Then use a contact cent or super 90 and glue it on.
Or you can order the repop on. But it think those Range near 100.00 with shipping.
A local upholster should be able to whip on up for 100.00 with vinyl.
Abe Lugo is offline   Reply With Quote
Old 09-11-2023, 11:10 PM   #5
Abe Lugo
Also you should think about redoing the rear window seal as that is the reason the board was crusty and wet.
Old 09-12-2023, 06:25 PM   #6
Daves55Sedan
I doubt the back window seal is leaky. They all get like that just from normal condensation overnight. But if you overlaid the cardboard (preferably a new piece) with vinyl, you won't have to look at that ugly mess in the future. The vinyl overlay might collect some moisture on top, but you can wipe it off. No matter what you put back there, it will fade in the sunlight unless you keep the car in a garage.
