Old 06-22-2023, 10:18 PM   #21
cousinjd
Default Re: y block ticking
Just a WAG but check for a rock in tire tread or a bolt or screw in tread. Good luck, little things cause big problems.
cousinjd is offline   Reply With Quote
Old 06-22-2023, 10:27 PM   #22
cousinjd
Check for a rock in tire tread or a bolt or screw in tread. little things are sometimes the bigggest headaches. Good luck.
Old 06-23-2023, 07:14 AM   #23
cvicky
cvicky's Avatar
manual says 3* for manual trans
what timing is suggested for 272 Holley 4 barrel tea pot standard trans
looking at wet carb and black tail pipes id say its running rich
but ill do the choke thing...
cvicky is offline   Reply With Quote
Old 06-23-2023, 03:21 PM   #24
paul2748
paul2748's Avatar
Initial advance setting by Ford were very conservative. Most Y's run better at more initial
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-23-2023, 04:23 PM   #25
cvicky
cvicky's Avatar
poured a lot of tranny fluid down carb
so much smoke neighbours almost called fire department
good news smoke came out between head and exhaust manifold 6 and 7
new gasket should fix that
Old 06-23-2023, 04:28 PM   #26
cvicky
cvicky's Avatar
paul my Y seems to like it around 12 degreese does that make sence to you
what would you put it at ???
Old 06-23-2023, 07:53 PM   #27
paul2748
paul2748's Avatar
I run mine 10 degrees (a stick and an auto) and they run good. You won't hurt anything at 12 but road test it to see if your happy with it. Both are warmed over 312's
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-24-2023, 12:26 PM   #28
cvicky
cvicky's Avatar
exhaust manifold is warped a bit in the middle i'll try grinding the ends a bit
Old 06-24-2023, 12:30 PM   #29
cvicky
cvicky's Avatar
next is my crankcase vent tube switch to pcv
wr do i get and what kind
i guess put hole in valve cover ...etc.
Old 06-24-2023, 02:33 PM   #30
Patrick brophy
It might not be my place to say so ,but the grinder is a not so good idea.
From the sounds of it you are expending a great deal of time and effort.
If that exhaust manifold is bad ,replace it. There are others to be found with very little effort.
By doing so ,you will correct the issue you are having. Attempting to solve your problem with a grinder will most likely result in a completely unusable part, and you will still have the same issue.
Same with the PVC valve .There are several threads here that will walk you thru how to go about this. it also tells what type of valley pan you need, or how to "adjust" the one you have.
I suggest you slow down and take the time to read them, it will save you a lot of time and aggravation down the road.
Patrick brophy is offline   Reply With Quote
Old 06-24-2023, 07:51 PM   #31
miker98038
miker98038's Avatar
If you going to salvage the manifold have a shop surface it. And put a straight edge on the head. Ford shipped new cars without exhaust gaskets, just flat surfaces. You’ll find a lot of manifolds with the end ears cracked off from trying to over tighten them on the gaskets that come in gasket sets. There’s some high temp RTV products that’ll live on headers that might help.
Recent article on PCV on yblocksforever. Part numbers, etc. Valve cover or valley pan, don’t ignore the baffles.
http://forums.y-blocksforever.com/Topic164478-1.aspx
miker98038 is online now   Reply With Quote
Old 06-25-2023, 12:03 AM   #32
Daves55Sedan
Daves55Sedan's Avatar
Depending upon where you live, you might be better off taking that exhaust manifold to a local engine rebuild shop and have them mill the bad surface down flat. Then you won't need to find a used manifold that may have problems of it's own.
Old 06-25-2023, 02:35 PM   #33
cvicky
cvicky's Avatar
how do i put a picture in my profile
Old 06-25-2023, 07:49 PM   #34
paul2748
paul2748's Avatar
Lot of BS on using gaskets on the exhaust manifolds. Yes, Ford did not use them. However, things get changed around, the disparate parts do not always fit precisely. Especially things that go through hot and cold cycles all the time. I use gaskets on the exhaust manifolds on my Y's. Never broke a manifold. Have to be careful when tightening them down, in a sequence like doing a cylinder head or an intake manifold. Start from the middle and go out. Don't tighten them up full bore the first time. Do it in steps.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-25-2023, 08:08 PM   #35
paul2748
paul2748's Avatar
Do you mean a picture under your name? That is an avatar.
At the top, click on User CP
Under settings, click on "Edit Avatar"
Click on circle under Custom Avatar
If you want to use a pic on your computer, click on "Browse"
Go to the picture on your computer you want to use and click on it. Then click on "OPEN" at bottom. The picture name will appear after "BROWSE"
Click on "save changes"
THis will do it (if you have Windows). May be different if you have Apple.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-25-2023, 10:18 PM   #36
afuncar
Check for rocks stuck in treads of tires.
afuncar is offline   Reply With Quote
Old 06-26-2023, 02:50 PM   #37
cvicky
cvicky's Avatar
thx Paul
as you can see i finally got my picture up.
Ticking noise is gone
new gasket and orange high heat gasket maker and i torqued # 7 exhaust first wr it was a bitt worped
i'll watch for another manifold
Old 06-26-2023, 03:41 PM   #38
dmsfrr
dmsfrr's Avatar
If you look closely at the bolt holes to the head you'll see that all but one hole is larger than the bolt diameter. Pretty sure this is to allow the manifold to expand and contract as it heats & cools, helping to take stress off so it's less likely to crack. Another reason the bolts shouldn't be over tightened.
Be aware there are several different styles and their diameter increased for '57.
http://www.y-block.info/casting/exhaust.html
Old 06-26-2023, 06:31 PM   #39
cvicky
cvicky's Avatar
your back
i wondered wr you wr
your usually the first one to answer my problems
and yes i'm torquing small whole first # 7 exhaust is my problem
i think i know wr there is a 56 manifold
good to know 57 may be different
Old 06-30-2023, 10:44 PM   #40
fordor41
fordor41's Avatar
I checked the link for the exh. manifolds. 1960's are listed as C2AZ both L&R. How could that be as C2 is 1962. Couldn't have part numbers 2 yrs ahead of production
fordor41 is offline   Reply With Quote
