Can the 9" long pressure plate bolt up to the 9 1/2" bolt pattern ?
Super Moderator
No.
This seems like a self-answering question.
If you need one try Fort Wayne Clutch, Ask for Lou.
Lou just rebuilt my pressure plate did excellent job
37 Ford Slantback 60hp. All steel nut and bolt restoration in process. Period correct hot rod. Boling Brothers Lincoln Brakes 39 Pedals Van Pelt Built 3spd HotRodWorks Banjo Rearend |
Pretty easy to redrill the flywheel.
Gramps |
I just looked up the spects. for the 9" PP the bolts holes are three sets of two 120 degs.
apart with a 5.187 diameter and two 5 1/16 x 18 threaded holes 2.844 C to C. The 9 1/2" PP bolt holes are 3.000 apart . Just a note a 10" long does not work at all. |
Thanks Ron. I will do that. I was just looking for a quick answer after drilling for a 10 long that does not work. Please see my last post Well back to the drawing board.
Not putting down The HAMB but i got so many stupid remarks i got so mixed up I ordered a 10 long. |
