Old 04-26-2023, 03:27 PM   #1
jimvette59
jimvette59's Avatar
Default Pressure Plate ?
Can the 9" long pressure plate bolt up to the 9 1/2" bolt pattern ?
jimvette59 is offline   Reply With Quote
Old 04-26-2023, 06:08 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Pressure Plate ?
No.
Old 04-26-2023, 06:11 PM   #3
DavidG
DavidG's Avatar
This seems like a self-answering question.
Old 04-26-2023, 07:27 PM   #4
Krylon32
If you need one try Fort Wayne Clutch, Ask for Lou.
Krylon32 is offline   Reply With Quote
Old 04-26-2023, 11:12 PM   #5
blueoval37
blueoval37's Avatar
Lou just rebuilt my pressure plate did excellent job
37 Ford Slantback 60hp. All steel nut and bolt restoration in process. Period correct hot rod.
Boling Brothers Lincoln Brakes
39 Pedals
Van Pelt Built 3spd
HotRodWorks Banjo Rearend
blueoval37 is offline   Reply With Quote
Old 04-27-2023, 07:45 AM   #6
jimvette59
jimvette59's Avatar
Thanks blueoval 37
Old 04-27-2023, 07:50 AM   #7
Ol' Ron
Ol' Ron's Avatar
Pretty easy to redrill the flywheel.
Gramps
Old 04-27-2023, 08:04 AM   #8
jimvette59
jimvette59's Avatar
I just looked up the spects. for the 9" PP the bolts holes are three sets of two 120 degs.
apart with a 5.187 diameter and two 5 1/16 x 18 threaded holes 2.844 C to C. The 9 1/2" PP bolt holes are 3.000 apart . Just a note a 10" long does not work at all.
Old 04-27-2023, 08:14 AM   #9
jimvette59
jimvette59's Avatar
Gramps
Thanks Ron. I will do that. I was just looking for a quick answer after drilling for a 10 long that does not work. Please see my last post Well back to the drawing board.
Not putting down The HAMB but i got so many stupid remarks i got so mixed up I ordered a 10 long.
