I was poking around Mike's A's and saw their coolant temp and oil pressure gauges.
What engine/cooling modifications need to be made to use them? |
There is a tap on the starboard side of the engine, below the distributor, that can be used to sense oil pressure. The temperature sensor must be screwed into the goose neck (coolant outlet). A goose neck with the proper tapped hole is available from the vendors, see
https://www.snydersantiqueauto.com/p...4021&cat=41737
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 01-20-2023 at 10:15 PM. |
The drilled water outlet is out of Stock at most vendors.
I used a stock gooseneck, just drilled a hole on the back side (towards the firewall), tapped some threads for the sending unit fitting and JB welded it in. The gooseneck is a bit thin there so be careful. I have seen some sending units that are a bit long & will bottom out on the front side so check your clearance before drilling the hole. You can back the fitting a thread or two then JB it. Some fellows put it on the side but it is in the way of torqueing the head nut there.
Good Evening...Vintage Precision makes a nice neck with a good thermostat. I've been running one for a few years and really like it. Ernie in Arizona
Stewart Warner makes a vintage “Wings” gauge in black or white. I have used them in several cars. I don’t have a picture of one in my A but here is what I mounted in my 35 pickup recently.
I used a SW temp only in the A, I felt loosing oil pressure was a rare occurrence and temp monitoring had the greatest value. I was trying to avoid dash clutter so I mounted the gauge on the drivers side kick panel and it looked natural. Because you are in the colder part of the USA the upper neck with a thermostat mentioned in post #5 may be a consideration.
Tim Downtown, Ca |
Hookup of temperature gauge sensor:
Bob Bidonde |
#10 | |
I have the Vintage Precision Thermostat on both my A's. Best you can get.
#13 | |
That is what I use—I like the placement of the thermostat close to the head. It’s a little pricy though. http://www.vintageprecision.com/prod...ing/index.html Sent from my iPhone using Tapatalk |
#14 | |
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
#15 |
I've got the neck with the thermostat and a vintage looking gauge. Always runs at 160.
#16 |
No oil pressure gauge, but here's my Rex-a-co temp gauge. I found a nifty steel gauge cup on Amazon which fits it perfectly and used the same hose clamp holding my turn signal switch to tie it down on the steering column. I like that it sits up high where it's easy to see instead of under the dash. Neat and clean.
#17 |
So glad I asked. Really helpful info all. I like that Vintage Precision piece. If it’s American made I’m ordering one!
#18 |
#19 |
https://www.summitracing.com/parts/h...BoCyKsQAvD_BwE
It's in a mount from Bert's https://modelastore.com/index.php?ro...roduct_id=4868 Here's the thermostat mount http://www.vintageprecision.com/prod...ing/index.html |
#20 |
What is the point of an oil pressure gauge on a non-pressurized oil system?
