#21 |
I like variety in my old fords. If the topic does not interest me, and there are many, I dont click on it. just that easy !
#22 |
8 BA in 31 A, generator, fan, and pullies in stock placement.
#23 | |
I think the key to asking Hotrod questions on this forum is to leave out the context enough that it is ambiguous. The technical aspects are still relevant. A little discretion. Otherwise the Hamb is better suited to most discussions concerning AV8s. I don’t mean that’s my opinion, just that there are a good amount of people on that board with a wealth of knowledge on the topic. |
#24 |
My friend just built a '30 AV8 with a 59A. He had a book that said to use a '32 wishbone. The '32 ended up being too long. That was a misprint in the book. A '33-'34 wishbone is shorter than a '32. It you use the stock '33-'34 wishbone with your Model A front spring to locate tour K-member, a 59A engine will end up with enough clearance for a generator mounted fan and still have a little clearance at the firewall. It's like that '33'-34 wishbone was made for building an AV8. It could not have worked out any better.
You do not want an 8BA for a couple of reasons. They are longer because of the extended water pumps for the late model distributor. But also, because in 1949 Ford eliminated the toque tube and went to a modern driveshaft with parallel rear leaf springs, they eliminated the castings in the later blocks for what most people call the chatter rods. Those are engine stabilizer rods that prevent the torque tube from pushing the engine forwards under acceleration. If you use a torque tube rear end your better off with the earlier blocks so you will have stabilizer rods from the block to the K-member. |
#25 |
While I agree the 59a is a better choice, there are lots of threads here on how to fabricate mounts for the steady rods on an 8ba block. I'm a 59a kinda guy , myself
#26 | |
#27 |
I just can't seem to find my way onto the HAMB.
Don't never get rid of nuthin! |
#28 |
#29 | |
Mike Bishop posted a fairly good explanation about his misprint concerning the front radius rod assembly on there but the photos were likely from Photobucket file sharing so they may be gone now. They used a 1932 part on the roadster project but printed that the 34 was used. Mike's article on the HAMB was on how to lengthen a 34 unit if you followed the Bishop/Tardel book and sourced one for a project. It is a good read. The HAMB also has multiple ways to use the 8BA in older cars that are dimensionally challenged. I for one believe the 8BA is more functionally adaptable than the older engines and especially on the rear end for transmission adaptation. There are many more 8BA survivor engines out there by comparison to the 59 series or earlier engines. |
#30 | |
Thanks |
#31 |
Theres lots of vintage ford hot rodders here. We don't talk much about SBC's, or vega steering boxes, but the interest and knowledge of vintage ford modifications is here. No need to run away
