Old 06-23-2022, 04:13 PM   #1
Don
Don's Avatar
Default 40-B cam verses 11A cam in dist
Will I notice any differences in performance? Gas mileage , acceleration,,
What will the additional advance give me?
DON P
Don is offline   Reply With Quote
Old 06-23-2022, 04:50 PM   #2
Ken/Alabama
Ken/Alabama's Avatar
Default Re: 40-B cam verses 11A cam in dist
The 11A has a better advance curve. Must use in conjunction with the 11A weights.
Old 06-24-2022, 11:08 AM   #3
35fordtn
35fordtn's Avatar
To change from the 40B to 11A you have to change the shaft, weights and the breaker plate. To me the advantage of using the 37-48 points is the best advantage of the conversion. The better advance curve helps but is not as drastic as people think.
Old 06-24-2022, 12:09 PM   #4
Don
Don's Avatar
I made up a spare dist with the 11A shaft and the small points,installed it awhile back,
I couldn’t see any difference at the time,maybe install one then the other,might be able to feel the difference,,
DON P
Old 06-24-2022, 10:27 PM   #5
Lawrie
Lawrie's Avatar
If your still using the flattop pistons you may have trouble with too much advance.
Lawrie
