Old 06-05-2022, 02:09 PM   #21
KULTULZ
KULTULZ's Avatar
Talking Re: Ford FE timing chain questions
Originally Posted by miker98038 View Post
Your other alternative is to degree the cam in with the slack out, and live with the shift in timing, or compensate for it. I don’t know that that matters. If it’s degreed in right for a daily driver it should still give many miles of good service. Normal usage and rpm’s won’t jump a gear. Race engines, get your wallet out.
Originally Posted by KULTULZ View Post
... uh ...
Isn't a loose timing set the reason you replace them?
30W hasn't kicked in yet ...?
... uh ...
You know I was only rattling your chain, right?
30W = COFFEE
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 06-05-2022, 04:26 PM   #22
NoahVail
Default Re: Ford FE timing chain questions
Quick update. I got my new chain from the store and first impressions are good. It has less slop. I'll semi-reassemble the setup with both so i can get some quantifiable results.
NoahVail is offline   Reply With Quote
Old 06-05-2022, 04:57 PM   #23
NoahVail
Full update: I just did some back and forth testing, and the new chain has the usual 5 degree's or so of slop. Way less than the last new one i put in. I did some back to back testing, and from my rough eye, it's about half as much slop. I'm going to reassemble the engine with this new one and that should be my solution.
Summary of thread: Whole lot of maybes that just ended up being bad new parts.
Old 06-05-2022, 06:56 PM   #24
miker98038
miker98038's Avatar
I guess I’ve led a sheltered life. I’ve never had one as bad as Noahvail got, even used. But I’m glad it seems to be fixed.
Go ahead and rattle my chain. Likely at my age I won’t hear it.
miker98038 is offline   Reply With Quote
Old 06-05-2022, 09:24 PM   #25
KULTULZ
KULTULZ's Avatar
Question Re: Ford FE timing chain questions
Were all of the new parts CLOYES?
Old 06-05-2022, 10:03 PM   #26
NoahVail
Yes they were. Turns out what i thought was also a parts store branded one was another cloyes. The new parts plague is effecting every manufacturer. I'll be telling their service guy's about all of this, and see where it leads.
Old 06-06-2022, 05:16 AM   #27
KULTULZ
KULTULZ's Avatar
Unhappy Re: Ford FE timing chain questions
I was afraid of that. Just like everything else, going to hell.
