Old 04-13-2022, 04:26 PM   #1
dschwartz
Default Valve seats
How to remove and install valve seats?
dschwartz is offline   Reply With Quote
Old 04-13-2022, 05:05 PM   #2
Karl Wolf
Karl Wolf's Avatar
Default Re: Valve seats
To remove- get washers that fit into the inside of the seat.
I used a stick welder to weld the washer to the inside of the seat.
Does not need to be perfect. This will shrink them, they will be easy to remove.
I had a company called K.O.Lee make 16 new seats to my measurements.
I took some plumbing parts to make a guide- fits the inside and flat top of the seat,
extends into the lifter below- so the seat is driven in perfectly flat- with a hammer.
I lube with never seize.
This worked for me- I have had the experience using proper machinery. (on other engines).
For many, this will be best to take to someone with the tooling and experience.
Karl
Karl Wolf is offline   Reply With Quote
Old 04-13-2022, 05:14 PM   #3
dschwartz
thank you
Old 04-13-2022, 08:36 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
I have removed the seats by just welding on the seat this easily shrinks them and they fall out and sometimes just break into pieces.
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 04-14-2022, 07:37 AM   #5
Ol' Ron
Ol' Ron's Avatar
What RR said, quick & easy.
Gramps
Old 04-14-2022, 09:25 AM   #6
flatford8
flatford8's Avatar
Not trying to be a smartass but are you sure you have removable seats? I’ve read some horror stories about when somebody tried welding them and they weren’t removable ….Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 04-14-2022, 11:36 AM   #7
supereal
supereal's Avatar
A job best left to a good machine shop.
supereal is offline   Reply With Quote
Old 04-14-2022, 05:58 PM   #8
Ronnieroadster
Its easy to see the insert inner edge. If someone tried to do what you wrote they really need glasses.
Old 04-14-2022, 06:29 PM   #9
enginepieces
We just put a small bead with the TIG you do not need to weld all around the seat. Three spots normally will shrink them. I no longer can see good enough and keep my hands still so this job has been passed on to the next generation. Trying to train the third generation but my 12 year old grandson shows no interest in greasy old machines.
enginepieces is offline   Reply With Quote
Old 04-15-2022, 12:54 PM   #10
flatford8
flatford8's Avatar
“ Old 12-17-2019, 07:59 PM #4
JWL
Default Re: Valve seats. How to remove?
Yes, a quick weld on the seat about as fast as possible. Ring will simply fall out. One word of caution---I once knew a guy to whom I explained my technique. Only too late he realized his block did not have seat rings. Ugly.
Never changed them myself but I remembered reading this …..Mark
