Old 02-26-2022, 07:41 AM   #1
Ed in Maine
Default My Victoria is Ruining My Shirts!
Yesterday I went on a club tour and the car never ran better. But, I came home with another dress shirt that has grease on the left shoulder from the female dovetail on the door jam. I don't realize it when it happens but to get my feet through the opening, I must be leaning back into the greasy slot in the dovetail. Has anyone else experienced this? When I am stepping out, going on a tour or a club meeting, I usually am wearing one of my better shirts.
Can anyone recommend a clear, heavy grease or other lubricant? Currently, I am using a heavy black wheel bearing grease. Thanks for your help. Ed
Old 02-26-2022, 08:09 AM   #2
Bob Bidonde
Bob Bidonde's Avatar
Default Re: My Victoria is Ruining My Shirts!
I see your problem although I haven't had it yet. I wonder if a clear piece of tape on the face of dovetail might work. Better yet, a piece of clear plastic sheet covering the entire face and secured with the dovetail's mounting screws.
Bob Bidonde
Old 02-26-2022, 08:21 AM   #3
nkaminar
nkaminar's Avatar
Someone gave me a duster, which is basically an overcoat to be worn while driving your pre WWW1 brass car on the dusty roads of the time. That may be a solution. You can put it on to drive the car and then take it off when you get to your destination. An old jacket would serve the same purpose. A light weight jacket for summer or Florida.
Old 02-26-2022, 08:30 AM   #4
Oldbluoval
Oldbluoval's Avatar
If it’s on your shirt …sooner or later on seat?
Old 02-26-2022, 08:46 AM   #5
1931 flamingo
1931 flamingo's Avatar
Remove the grease...................
Paul in CT Mine never had it.
Old 02-26-2022, 10:08 AM   #6
TerryO
TerryO's Avatar
I don't grease mine but instead I put a very little bit of chapstick on them when they start to stick.Just rub my finger on the chapstick then rub the dovetail, no greasy surface but no sticking door...
TOB
TerryO is offline   Reply With Quote
Old 02-26-2022, 10:46 AM   #7
katy
katy's Avatar
Take the shirt off before you get in the car.
Old 02-26-2022, 11:20 AM   #8
Y-Blockhead
Y-Blockhead's Avatar
Maybe stop "using a heavy black wheel bearing grease"??
I noticed a hole on either side of the four dovetails on my Town Sedan and inside the dovetail has a piece of felt (the dovetails are hollow). Occasionally I wipe them clean and put a few drops of light oil in the holes. I don't know if this was what the holes and felt were originally meant for but it appears to be and seems to work.
Old 02-26-2022, 11:29 AM   #9
ronn
wear a slicker..............
Old 02-26-2022, 12:10 PM   #10
katy
katy's Avatar
Originally Posted by Y-Blockhead View Post
I noticed a hole on either side of the four dovetails on my Town Sedan [/COLOR][/SIZE][/FONT]
I wonder if those holes would be for rubber bumpers?
Old 02-26-2022, 01:44 PM   #11
TMarsh
as what yblockhead wrote, that is what the holes are for, oil
TMarsh is offline   Reply With Quote
Old 02-26-2022, 09:57 PM   #12
Anteek29
Anteek29's Avatar
Victoria is merely marking her territory!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 02-26-2022, 10:47 PM   #13
al's28/33
al's28/33's Avatar
wear a black shirt.
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 02-26-2022, 10:55 PM   #14
1928Mustang
I use bee's wax on my victoria
1928Mustang is offline   Reply With Quote
Old 02-27-2022, 03:00 AM   #15
updraught
updraught's Avatar
Silicon spray is better for door locks here, dust doesn't stick and wear them out. Spray often. It dries clear.
Wash out the grease first tho.
updraught is offline   Reply With Quote
Old 02-27-2022, 07:27 AM   #16
daren007
Clear tape What?
daren007 is offline   Reply With Quote
Old 02-27-2022, 07:43 AM   #17
Oldbluoval
Oldbluoval's Avatar
Originally the dovetails had felt inserts. The holes are to allow oiling not greasing I would suppose
Old 02-27-2022, 09:25 AM   #18
deuce5wndw
deuce5wndw's Avatar
I have had good luck using Shout on grease stains!
deuce5wndw is offline   Reply With Quote
Old 02-28-2022, 12:04 AM   #19
Bill Cal.
I would say if everything else that could go wrong isn't, this is the least of your worries.
Bill Cal. is offline   Reply With Quote
Old 02-28-2022, 12:27 AM   #20
Certimafied
Certimafied's Avatar
Brake Cleaner too, its like a dry cleaning solution. Check it won't ruin colors first though.
Certimafied is offline   Reply With Quote
