The Ford Barn
-   -   My Victoria is Ruining My Shirts! (https://www.fordbarn.com/forum/showthread.php?t=310441)
Ed in Maine 02-26-2022 07:41 AM
Yesterday I went on a club tour and the car never ran better. But, I came home with another dress shirt that has grease on the left shoulder from the female dovetail on the door jam. I don't realize it when it happens but to get my feet through the opening, I must be leaning back into the greasy slot in the dovetail. Has anyone else experienced this? When I am stepping out, going on a tour or a club meeting, I usually am wearing one of my better shirts.
Can anyone recommend a clear, heavy grease or other lubricant? Currently, I am using a heavy black wheel bearing grease. Thanks for your help. Ed
Bob Bidonde 02-26-2022 08:09 AM
Re: My Victoria is Ruining My Shirts!
1 Attachment(s)
I see your problem although I haven't had it yet. I wonder if a clear piece of tape on the face of dovetail might work. Better yet, a piece of clear plastic sheet covering the entire face and secured with the dovetail's mounting screws.
nkaminar 02-26-2022 08:21 AM
Someone gave me a duster, which is basically an overcoat to be worn while driving your pre WWW1 brass car on the dusty roads of the time. That may be a solution. You can put it on to drive the car and then take it off when you get to your destination. An old jacket would serve the same purpose. A light weight jacket for summer or Florida.
Oldbluoval 02-26-2022 08:30 AM
If it’s on your shirt …sooner or later on seat?
1931 flamingo 02-26-2022 08:46 AM
Remove the grease...................
Paul in CT Mine never had it.
TerryO 02-26-2022 10:08 AM
I don't grease mine but instead I put a very little bit of chapstick on them when they start to stick.Just rub my finger on the chapstick then rub the dovetail, no greasy surface but no sticking door...
TOB
katy 02-26-2022 10:46 AM
Take the shirt off before you get in the car.
Y-Blockhead 02-26-2022 11:20 AM
Maybe stop "using a heavy black wheel bearing grease"??
I noticed a hole on either side of the four dovetails on my Town Sedan and inside the dovetail has a piece of felt (the dovetails are hollow). Occasionally I wipe them clean and put a few drops of light oil in the holes. I don't know if this was what the holes and felt were originally meant for but it appears to be and seems to work.
ronn 02-26-2022 11:29 AM
wear a slicker..............
katy 02-26-2022 12:10 PM
Originally Posted by Y-Blockhead (Post 2108395)
I noticed a hole on either side of the four dovetails on my Town Sedan [/COLOR][/SIZE][/FONT]
I wonder if those holes would be for rubber bumpers?
TMarsh 02-26-2022 01:44 PM
as what yblockhead wrote, that is what the holes are for, oil
Anteek29 02-26-2022 09:57 PM
Victoria is merely marking her territory! :)
al's28/33 02-26-2022 10:47 PM
wear a black shirt.
1928Mustang 02-26-2022 10:55 PM
I use bee's wax on my victoria
updraught 02-27-2022 03:00 AM
Silicon spray is better for door locks here, dust doesn't stick and wear them out. Spray often. It dries clear.
Wash out the grease first tho.
daren007 02-27-2022 07:27 AM
Clear tape What?
Oldbluoval 02-27-2022 07:43 AM
Originally the dovetails had felt inserts. The holes are to allow oiling not greasing I would suppose
deuce5wndw 02-27-2022 09:25 AM
I have had good luck using Shout on grease stains!
Bill Cal. 02-28-2022 12:04 AM
I would say if everything else that could go wrong isn't, this is the least of your worries.
Certimafied 02-28-2022 12:27 AM
Brake Cleaner too, its like a dry cleaning solution. Check it won't ruin colors first though.
