Old 02-15-2022, 03:11 PM   #1
Fredb_
Fredb_'s Avatar
Default LH or RH?
I think this is 37-38 sedan or coupe windshield garnish. Is it LH Driver side or RH passenger side?
Thanks everyone
Fredb_ is offline   Reply With Quote
Old 02-15-2022, 03:14 PM   #2
petehoovie
petehoovie's Avatar
Default Re: LH or RH?
Old 02-15-2022, 04:39 PM   #3
Brian
Brian's Avatar
RH pass side as evidenced by the cutout for the windscreen hinge
Brian is online now   Reply With Quote
Old 02-15-2022, 05:11 PM   #4
Fredb_
Fredb_'s Avatar
So as I have it pictured, it is upside down?
Old 02-15-2022, 05:29 PM   #5
Lawson Cox
Lawson Cox's Avatar
When you are sitting behind the steering wheel of a car, facing forward, everything to your left is the left side of the vehicle and everything to your right is the right side of the vehicle. ALWAYS.
Old 02-15-2022, 05:49 PM   #6
Fredb_
Fredb_'s Avatar
Yes, I'm just trying to determine if the small notch is for the upper hinge or if the longer notches are on top. I was assuming this was a LH driver side garnish and the hinge fits in the smaller notch.
Thanks
Old 02-15-2022, 06:03 PM   #7
Zeke3
Zeke3's Avatar
The large opening is for the defroster, if installed, and the other slot is for the windshield crank arm. Definitely a RH molding. You have it pictured correctly with the small slot to the top.
Zeke3 is offline   Reply With Quote
Old 02-15-2022, 07:23 PM   #8
1937sedandelivery
It looks like a LH molding to me and is pictured correctly.
gregg
1937sedandelivery is offline   Reply With Quote
Old 02-15-2022, 07:28 PM   #9
Lanny
Lanny's Avatar
It looks to be the left (driver) garnish molding.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 02-15-2022, 07:50 PM   #10
40cpe
40cpe's Avatar
I just looked at my '38 coupe. It is for the right side. When installed, it will be reversed with the cut-outs pictured facing forward and the closed side on the right.
Old 02-15-2022, 08:13 PM   #11
Lanny
Lanny's Avatar
Yes, I agree, as I take a better look at it, the right side is correct.
Old 02-16-2022, 03:18 PM   #12
Fredb_
Fredb_'s Avatar
Thanks guys. I was looking at it with the wrong side facing forward too and thought it was for the driver or LH side, but it is actually for the RH side as some of you originally stated. Thanks again for the help on it.
