Old 12-09-2021, 09:33 AM   #21
rotorwrench
rotorwrench's Avatar
Default Re: Flipped uprights '49 Club Coupe
Labor is money too. The older you get the more time has an affect. I love to fab stuff but I've learned to balance my time a lot better on projects and especially if someone else can do it cheaper than I can. My time gets more valuable every year.
Old 02-08-2022, 06:34 PM   #22
CJStefan
Exactly how bad is the bumpsteer with flipped uprights and the steering arms not heated and bent down?
CJStefan is offline   Reply With Quote
Old 02-09-2022, 01:10 AM   #23
51 MERC-CT
51 MERC-CT's Avatar
Flipped uprights and altered steering arms have little or nothing to do with bumpsteer.
The factory bumpsteer will still be present unless a bumpsteer kit that moves the inner tyrod ends forward is installed.
Old 02-09-2022, 06:13 PM   #24
Shoebox
Shoebox's Avatar
Is this the kit offered by Jamco?
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 02-09-2022, 06:22 PM   #25
51 MERC-CT
51 MERC-CT's Avatar
Have no idea but it is like the one that I installed many years ago made by Fatman. (the Jamco one may be made by Fatman)
Old 02-09-2022, 07:21 PM   #26
Shoebox
Shoebox's Avatar
Yes, you are correct in that Fatman makes that kit. Having this setup on your car for some years, I take it you felt it worked/was worth it? Thank you.
32 Ford roadster
39 Mercury Towncar
Old 02-09-2022, 07:55 PM   #27
51 MERC-CT
51 MERC-CT's Avatar
If you know what bumpsteer is and have experienced it then the kit works and to me has been worth it.
Old 02-10-2022, 08:34 AM   #28
chuck stevens
chuck stevens's Avatar
knock the rivets out of the lower control arm, spring mounts, put a one inch spacer in, replace the stock bolts with grade 8 she'll be low. And it is totally reversable and easy. The lowering block can be aluminum or steel, 1" by 1 1/4" , kinda old fashion but it works.
chuck stevens is offline   Reply With Quote
Old 02-10-2022, 09:38 AM   #29
51 MERC-CT
51 MERC-CT's Avatar
Good grief, why go thru all that nonsense when shorter Aerostar springs accomplish the same thing?
Old 02-10-2022, 12:20 PM   #30
Shoebox
Shoebox's Avatar
I am well aware of what bumpsteer is. Based on your answer I will keep this setup on the "to do list" for my '51.
32 Ford roadster
39 Mercury Towncar
