Does anyone have the measurements for the wood that goes on top of the frame and under the bed. Mine were toast and I would like to fabricate the wood mounts for front and back of the bed. I have the 1/2 ton.
I did a search and did not turn up anything. Thanks for any info. |
I will look through my slips and directions from Northern Classic where I ordered my bed and wood kit from, it was sad to see them close up shop several years ago.
I will be tinkering on the T this weekend and could do some measurements as well if you need. Scott |
thanks Scott, any measurements you could provide will be helpful.
Thanks, Ken |
If you aren't going for points at a show, I did those parts with steel on my tonner (and that's from a career woodworker). At the axle hump on the frame, I thought the wood got pretty weak when milled with the angle. I used rectangular tubing flat ways with a wedge under the low side. 1/4" wall tubing is still pretty strong laid flat.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
GB it is highly unlikely it will ever be entered in a show that judges while I own it. I was looking at the subframe that the boards in the bed screw down to yesterday evening and it is toast also will have to fabricate new one. Are they other year models of subframe that is the same or close to 39?
#6 | |
Are you looking for info on the wood sub frame that is used under a (not stock) wood bed floor?
38Bill, I'm looking for the wood spacers that go under a stock bed. I'm calling the hat channel metal frame that the wood bed planks screws down to a subframe for lack of knowing what its real name is. I want to make my own wood blocks that go from the frame up to the bed that keeps it level.
MEMBER EMERITUS
Try cmwtrucks.com
They advertise 38-41 Ford pickup truck bed mount wood kit for $115. |
Thanks swoopNZ, I'm looking for the measurements to make my own.
Thanks, |
Sounds like your looking for info on the box to frame mounting blocks like in the photo? I didn't make drawings of mine but I think I can get measurements for you if that's what you need.
(Are you using the stock metal box floor?) |
38bill,
That is exactly what I am looking for measurements for both front and back wood blocks for stock bed. That picture helps a lot I can fabricate the rear one is the front one behind the cab the same? |
#13 |
That's the rear block here is the front. My truck is parked on my drive up ramp/lift if you want me to get some better measurements.
#14 |
Thanks 38bill, no need for further measurements I got it from the two pictures. I really appreciate you sending the pictures. I'm off to the lumber yard.
#15 |
If you run into any problems and need measurements just send me a pm.
#16 |
Do you have photos or measurements of the wood blocks that go around the wheel well openings on my 39 pickup? I've found the front and rear supports just nothing on the side pieces.
