Old 10-15-2021, 10:47 AM   #1
mustangbrandon
mustangbrandon's Avatar
Default 59AB early cam ideas
Barn inhabitants:
First: Need to find the "cam button" so I can run a helmet distributor. It currently has crab. I do have the right timing cover, but need the spacer. I cannot locate it anywhere online.
Second: Need a cam recommendation. Has NOS offy heads and intake. Looking for a "mild" option, something available new. There's a ton of cool old grinds but I don't think I'd be able to find one. Car is a stock 41 Convertible, just looking for a little extra to take advantage of the parts that came with it. While I love the L100 etc, I need something between that and stock. Any of the Schneider cams decent?
Thanks!!
Brandon
Currenty in the stable:
1928 Model A Roadster (in family 50+ years)
1935 Deluxe Tudor slantback
1935 Ford Pickup
1941 Business Coupe
1949 F1 Pickup
1955 Thunderbird
1956 Chevy Bel Air (yea, I know)
1964 Plymouth Fury 383 4 spd (yea, I know)
1965 A Code Mustang Fastback
1966 Fairlane
1979 Ford E250 Chateau Super Van
mustangbrandon is offline   Reply With Quote
Old 10-15-2021, 12:26 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 59AB early cam ideas
Brandon to switch from helmet to crab you need a distributor adapter/ spacer. The early cam is longer.
Old 10-16-2021, 09:55 AM   #3
Ol' Ron
Ol' Ron's Avatar
To switch to an aftermarket cam in a relatively stock engine is quite expensive, and any cam you choose will reduce low end torque. Your best bet would be to increase compression. Any cylinder head you choose, stock or aftermarket can be angle milled over the valves to leave .050" clearance. Usually around .070/.080, now this stock engine will have around 8:1 Cr, bored to 5/16 9:1 all for less money than a cam assy. Using a modified SBC distributor and 2GC carb. Unfortunately, the engine will look like it's perfectly stock. The upside, more power where you need it and fantastic gas mileage/
Gramps
Old 10-16-2021, 08:06 PM   #4
36coupe
36coupe's Avatar
https://www.speedwaymotors.com/Flath...pter,6003.html
Cam button
36coupe is offline   Reply With Quote
Old 10-17-2021, 08:07 AM   #5
KiWinUS
KiWinUS's Avatar
Originally Posted by 36coupe View Post
That button is to convert a short nose crab style cam to a helmet distributor. The OP wants to do the opposite.
Old 10-17-2021, 05:33 PM   #6
36coupe
36coupe's Avatar
I must be missing something he wants to run a helmet style currently has a crab style. That’s what I read in the first post?
My 38 has a 59ab and button under the helmet.
Old 10-17-2021, 08:03 PM   #7
JSeery
JSeery's Avatar
Just about any supplier should have the cam buttons.
