Old 10-03-2021, 01:24 PM   #1
o2bnkc
o2bnkc's Avatar
Default Headlight problems
The other night I was coming home (1940 Deluxe, 6 volt, positive ground) and the headlights started flickering off and on. The first thing I thought of was a partially broken wire somewhere. I didn't find a broken wire anywhere, but when I pulled out the switch on the dash and turned it on, the headlight wire became hot to the touch. I've got 6.37 volts coming out of the switch to the headlight wire so I assume the switch is good. Do I have a bare spot somewhere grounding to the car? Electrical is not my strong suite. Thanks.
A Proud Navy Veteran
o2bnkc is offline   Reply With Quote
Old 10-03-2021, 03:11 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Headlight problems
Can be something as simple as dirty bad battery post connections.
Everything else you have to trace.
Old 10-03-2021, 04:31 PM   #3
o2bnkc
o2bnkc's Avatar
Now the taillight wire is getting hot. It was smoking the connector by the firewall in the engine compartment When I disconnect it, the headlight wire cools off. With just the parking lights on, the taillights are very bright. With the headlights on, they are pretty dim.
Old 10-03-2021, 04:38 PM   #4
TJ
TJ's Avatar
Follow the light wires from the switch all the way to the front and back. Sounds like you have a bare wire touching some metal. If you have an old wire harness it may be time for a new one. '40 has a circuit breaker did you check it to see if it was getting hot?
Old 10-03-2021, 06:47 PM   #5
o2bnkc
o2bnkc's Avatar
The current wiring harness was installed in 2012. It seems that both the headlight and taillight wires are overheating when the switch is pulled out. I've traced all the parts of each wire I can see. Where is the circuit breaker?
Old 10-03-2021, 07:28 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
You can check the lines using the schematic as a reference.
This shows the location of the circuit breaker.
Old 10-04-2021, 08:47 AM   #7
TJ
TJ's Avatar
The circuit breaker is on the inside of the firewall just above the steering column. Also check your dimmer switch as the problem could be there.
Old 10-04-2021, 10:31 AM   #8
19Fordy
19Fordy's Avatar
Be sure to check all the slip in wire connectors that join the wires together
Old 10-04-2021, 11:03 AM   #9
corvette8n
corvette8n's Avatar
Also make sure you have good grounds everywhere, wire brush, file whatever you need to do to get clean, bright, tight grounds.
Old 10-04-2021, 11:16 AM   #10
51 MERC-CT
51 MERC-CT's Avatar
And if you clean all the connections, I have had good luck lightly coating the connections with dielectric grease before reassembly to help keep future corrosion from forming.
Old 10-04-2021, 04:41 PM   #11
4dFord/SC
4dFord/SC's Avatar
Flashing headlights is the 1940 circuit breaker's way of telling you there is a short somewhere.
4dFord/SC is offline   Reply With Quote
Old 10-05-2021, 08:27 PM   #12
o2bnkc
o2bnkc's Avatar
Thanks for all the suggestions, guys. I don't see anything obvious yet. My dimmer switch is not even hooked into the wiring and I don't see any bare wires yet. Could the light switch itself, be bad?
Old 10-05-2021, 11:10 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
My dimmer switch is not even hooked into the wiring.
IF your dimmer is not even hooked into the headlight circuit (WHY?), how are you dimming headlights? This is obviously not normal, and indicates that someone has screwed with the system. Any other notable anomalies? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-06-2021, 09:11 PM   #14
o2bnkc
o2bnkc's Avatar
LOL! I thought you meant the dimmer control on the dashboard lights!! So the foot switch can cause problems?
Old 10-06-2021, 09:24 PM   #15
40cpe
40cpe's Avatar
Do you know that a 6V harness was used when it was rewired?
Old 10-06-2021, 09:54 PM   #16
o2bnkc
o2bnkc's Avatar
I assume it was. The wire cloth coverings match the same color code as the original wiring according to my shop and owners manual. Red/yellow tracers for the headlights and a black wire for the taillights. I can't find a circuit breaker, though. I hooked up the ignition resister when I first got the car, but isn't the circuit breaker supposed to be up there by it? Can the dash switch be bad? That's the only place where the headlight and taillight wires meet up, and they both get hot.
Old 10-06-2021, 11:12 PM   #17
ford38v8
ford38v8's Avatar
The original circuit breaker does not resemble a modern unit, but rather, appears as a simple small black box, mounted on the same rectangular fiberboard as the ignition resistor. You said you hooked up the resistor, so I’m wondering if perhaps the resistor is routed incorrectly to the lighting circuit via the circuit breaker?
Alan
Old 10-07-2021, 02:49 AM   #18
V8COOPMAN
V8COOPMAN's Avatar
They should be mounted on the same board, similar to this. DD
T5 W/TORQUE TUBE
Old 10-07-2021, 12:16 PM   #19
drolston
drolston's Avatar
Especially the ones on the frame rail just behind the radiator, on the left/driver side. That bunch is more exposed to getting jostled loose, and to corrosion.
If the dimmer switch is not connected, it may be that someone wired it so that both the high and low headlight beams come on at the same time. That would double the normal current load through the switch, wiring and circuit breaker, probably causing the circuit breaker to cycle and wires to get hot.
Old 10-07-2021, 08:18 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
He finally explained in post #14 that he was referring to the DASHBOARD LIGHTING dimmer (rheostat). DD
T5 W/TORQUE TUBE
