I acquired this in line electric fuel pump in some parts I purchased. It’s a new pump and was still sealed in the plastic bag. I know it came from Fifth Avenue Parts in Kansas complete with instructions. Problem is that I don’t know if it’s 6 volt or 12 volt. There aren’t any other markings on it except for the ones in the photo. I’ve reached out to them but no luck. I think Randy who operated the place passed away. So is there anything I can do to determine whether or not it’s 6 or 12 volt ??
Ken....Going by those numbers seen printed on the pump, it MAY be a Carter, and LIKELY, 12v. None of this FOR SURE, though. DD |
Try it on 6volts FIRST. If it works, use it. If not try 12 volts.
Some of those Carters, some vendors have said they'll work on either 6 or 12v. I've always wondered about that.
Carter is a good company. Looks like a push/pull pump. Didn't know they made those. Rule of thumb, 6v on 12v no harm. 12v on 6v well. |
