Old 12-12-2020, 09:14 PM   #1
Gick70
Default 1952 ford f1,door sag
Door sag,anybody have any luck with a certain fix,drill for bigger bushings and pins,or hinge replacement?
Gick70 is offline   Reply With Quote
Old 12-12-2020, 10:36 PM   #2
alanwoodieman
Default Re: 1952 ford f1,door sag
are the pins loose in the hinge? if so drill for larger pins, if not place a piece of wood between lower hinges and gently close the door and push on it, usually raises the rear of the door to free it up
Old 12-13-2020, 09:53 AM   #3
marko39
After replacing the body rubber shims on my 39 Tudor, both doors had a sag to them. They fit fine before. I removed the shim at the B pillar and that brought the doors up about 1/4" which is much better.
marko39 is offline   Reply With Quote
