Old 12-10-2020, 07:01 PM   #1
frederic
Default installing heater hose fitting
going to install a metal heater hose adaptor/fitting into the front lower radiator hose. other than making a nice tight hole does one use any type of sealer on the flat surfaces
thanks a bunch
Frederic [email protected]
frederic is offline   Reply With Quote
Old 12-10-2020, 07:17 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: installing heater hose fitting
thanks a bunch
I always apply Indian Head Shellac available at Napa (about $2). Be certain to follow directions.
This stuff has been around for decades for good reason.
Old 12-11-2020, 09:44 AM   #3
1931 flamingo
1931 flamingo's Avatar
Also, I believe it was "Kube" who told me when I asked, angle it towards the fender, NOT verticle, so the fan doesn't hit the hose.
Paul in CT
Old 12-11-2020, 11:24 AM   #4
Automotive Stud
Automotive Stud's Avatar
Last one I installed was probably 15 years ago, I might have put some RTV on there if I recall. It probably doesn't really need anything. It's still been leak free.
Automotive Stud is offline   Reply With Quote
Old 12-11-2020, 11:34 AM   #5
deuce_roadster
deuce_roadster's Avatar
Choose a hole punch that creates a nice round snug fitting to the pipe. You can experiment on a flat piece of rubber like an old radiator hose, inner tube or something to find the right punch if you have one of those sets that goes from maybe 1/8 to 3/4 inch. I haven't had one of those ever leak without a sealant but the Indian Head Shellac is a good idea.
Old 12-11-2020, 09:41 PM   #6
Shu47
Shu47's Avatar
When I put mine in I made sure the hole was a tight fit and didn't use anything else. Has never leaked
Shu47 is offline   Reply With Quote
Old 12-12-2020, 07:39 PM   #7
russcc
Here is photo of the orientation on a V8 85 '40 Ford. The fan clears the hose by about 3/8", and the fitting angle makes for gradual bed in the heater hose.
Old 12-13-2020, 01:55 PM   #8
old31
Use a step drill to drill the hose and permatex2 to seal the parts and threads. Works very well.
old31 is offline   Reply With Quote
Old 12-14-2020, 11:07 AM   #9
frederic
Thanks all
Good ideas, some times the “simplest” appearing jobs can have the most complicated process.
Frederic
