Old 04-29-2020, 05:34 PM   #1
3739ford
3739ford's Avatar
Default 1939 Ford pickup bed wood
Does anyone have the measurements for the wood that goes on top of the frame and under the bed. Mine were toast and I would like to fabricate the wood mounts for front and back of the bed. I have the 1/2 ton.
I did a search and did not turn up anything.
Thanks for any info.
3739ford is offline   Reply With Quote
Old 04-29-2020, 06:32 PM   #2
39portlander
39portlander's Avatar
Default Re: 1939 Ford pickup bed wood
I will look through my slips and directions from Northern Classic where I ordered my bed and wood kit from, it was sad to see them close up shop several years ago.
I will be tinkering on the T this weekend and could do some measurements as well if you need. Scott
39portlander is offline   Reply With Quote
Old 04-29-2020, 08:10 PM   #3
3739ford
3739ford's Avatar
thanks Scott, any measurements you could provide will be helpful.
Thanks,
Ken
Old 04-29-2020, 09:30 PM   #4
GB SISSON
GB SISSON's Avatar
If you aren't going for points at a show, I did those parts with steel on my tonner (and that's from a career woodworker). At the axle hump on the frame, I thought the wood got pretty weak when milled with the angle. I used rectangular tubing flat ways with a wedge under the low side. 1/4" wall tubing is still pretty strong laid flat.
Old 04-30-2020, 07:57 AM   #5
3739ford
3739ford's Avatar
GB it is highly unlikely it will ever be entered in a show that judges while I own it. I was looking at the subframe that the boards in the bed screw down to yesterday evening and it is toast also will have to fabricate new one. Are they other year models of subframe that is the same or close to 39?
Old 04-30-2020, 10:08 AM   #6
TJ
TJ's Avatar
I believe 38-41 used the same bed and the chassis was the same. Wood should be the same.
Old 04-30-2020, 01:19 PM   #7
38bill
38bill's Avatar
Are you looking for info on the wood sub frame that is used under a (not stock) wood bed floor?
38bill is offline   Reply With Quote
Old 04-30-2020, 03:06 PM   #8
3739ford
3739ford's Avatar
38Bill, I'm looking for the wood spacers that go under a stock bed. I'm calling the hat channel metal frame that the wood bed planks screws down to a subframe for lack of knowing what its real name is. I want to make my own wood blocks that go from the frame up to the bed that keeps it level.
Old 04-30-2020, 04:24 PM   #9
swoopNZ
MEMBER EMERITUS
Try cmwtrucks.com
They advertise 38-41 Ford pickup truck bed mount wood kit for $115.
swoopNZ is offline   Reply With Quote
Old 04-30-2020, 05:25 PM   #10
3739ford
3739ford's Avatar
Thanks swoopNZ, I'm looking for the measurements to make my own.
Thanks,
Old 05-01-2020, 10:33 AM   #11
38bill
38bill's Avatar
Sounds like your looking for info on the box to frame mounting blocks like in the photo? I didn't make drawings of mine but I think I can get measurements for you if that's what you need.
(Are you using the stock metal box floor?)
Old 05-01-2020, 11:08 AM   #12
3739ford
3739ford's Avatar
38bill,
That is exactly what I am looking for measurements for both front and back wood blocks for stock bed. That picture helps a lot I can fabricate the rear one is the front one behind the cab the same?
Old 05-01-2020, 11:55 AM   #13
38bill
38bill's Avatar
That's the rear block here is the front. My truck is parked on my drive up ramp/lift if you want me to get some better measurements.
Old 05-01-2020, 01:28 PM   #14
3739ford
3739ford's Avatar
Thanks 38bill, no need for further measurements I got it from the two pictures. I really appreciate you sending the pictures. I'm off to the lumber yard.
Old 05-01-2020, 07:38 PM   #15
38bill
38bill's Avatar
If you run into any problems and need measurements just send me a pm.
Old 11-05-2021, 02:00 PM   #16
eric huffman
Do you have photos or measurements of the wood blocks that go around the wheel well openings on my 39 pickup? I've found the front and rear supports just nothing on the side pieces.
eric huffman is offline   Reply With Quote
