Old 03-20-2011, 08:19 AM   #1
bobs36
Default best plugs to use in stock 36 engine
i have been using champion, suggestion was ngk, any opions would be helpful,
also on spark plu wire st?, thank you, bob
bobs36 is offline   Reply With Quote
Old 03-20-2011, 09:39 AM   #2
Brendan
Brendan's Avatar
Default Re: best plugs to use in stock 36 engine
i have NKG in my 35 motor
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 03-20-2011, 10:22 AM   #3
ken ct
After 25 yrs of using Champs i tried a set of NGK. Threw in the garbage can after a mth. Went back to champ. I use "D-21" fairly hot plug and works just fine as before the NGK. OMO. ken ct.
ken ct is offline   Reply With Quote
Old 03-20-2011, 10:26 AM   #4
Pat/Ohio
Pat/Ohio's Avatar
I have had good luck with AC-216 in both my '35 & '40 motors. Pat
Pat/Ohio is offline   Reply With Quote
Old 03-20-2011, 06:52 PM   #5
ken ct
Pat 35 takes 18mm plugs/40 take 14 mm cant be same # plug. ken ct.
Old 03-20-2011, 08:03 PM   #6
Lawson Cox
Lawson Cox's Avatar
Good eye Ken. How is the no smoking thing progressing? Great, I hope.
Old 03-20-2011, 08:36 PM   #7
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I think any of those early engine are better off with a little hotter plug than thay call for. Walt
Old 03-20-2011, 09:10 PM   #8
PhoenixFear
My coworker says he rarely sells Champions because of how bad they are. They have the worst resistance that he has said. I personally stick with Champions on the older stuff though. Have had no problems. Next I would pick AC Delco.
PhoenixFear is offline   Reply With Quote
Old 03-20-2011, 10:30 PM   #9
uncle buck
uncle buck's Avatar
That sounds more like an Autolite number to me, Is that what you mean't to say?
uncle buck is online now   Reply With Quote
Old 03-20-2011, 10:47 PM   #10
Keystone 34 3w
Keystone 34 3w's Avatar
Motorcraft SP-484 BTS8 . These are Amerian made and designed by Ford Motor Company. They have black parkerized base and a threaded top.
Keystone 34 3w is offline   Reply With Quote
Old 03-22-2011, 09:42 AM   #11
Pat/Ohio
Pat/Ohio's Avatar
Ken...You are correct.....I knew that! I have too many cars! Is that possible? lol Pat
Old 03-22-2011, 09:46 AM   #12
ken ct
Yea i had 2 @ 1 time it was 1 too many.See you in Auburn in Augest. ken ct.
Old 03-22-2011, 10:45 AM   #13
ajohn
ajohn's Avatar
Here is a little different twist for you.I buy adapters and run 14mm plugs in mine.Why?Because of the vast selection of heat ranges and they just seem to run better to me.Just an opinion. James
ajohn is offline   Reply With Quote
Old 03-27-2011, 12:02 PM   #14
andyg
andyg's Avatar
autolite 216 works in my not so stock 36 motor.
champion h-10's went straight in the trash can and any champions that i find laying around the shop go straight in the trash can.
old champions were good. new ones are some of the worst on the market.
the h-10's in my recently purchased stock 40 looked like brand new and run like crap. put in a set of autolite 216's and it runs like a champ!...excuse the expression. and that's about the 4th time that same senerio has played out for me. just my penny's worth!
andyg is offline   Reply With Quote
Old 03-30-2011, 11:30 PM   #15
southfork
southfork's Avatar
I use autolite 216's in my 1950 Fordson 8N tractor. They work real good in that banger too!
southfork is offline   Reply With Quote
