Old 10-21-2019, 08:19 PM   #1
Newc
Newc's Avatar
Default '39 V8 60 Vin numbers ///strange numbers//////
Hi all; I just drug in a true '39 V8 60 car. All seems correct, tube axle, 4.44 rear diff and 23 tooth speedo turtle. No eng/trans. The vin is odd to me, and looks totally original-fonts/spacing, ect. How about this: star 54-475XXX star the X's are my secrecy. Anyway I have never seen a 54- only the usual 18- . Your ideas please. thanks Newc
Old 10-21-2019, 08:32 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: '39 V8 60 Vin numbers ///strange numbers//////
V8-60s began with the "54"....NOT "18"! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 10-21-2019, 09:18 PM   #3
Newc
Newc's Avatar
Wow; Thanks Coopman!
Old 10-22-2019, 09:21 AM   #4
cas3
i always thought the tube axle was 37 only, did all the 60's get them?
Old 10-22-2019, 10:55 AM   #5
KGS
KGS's Avatar
The tube axle was released for use in July of '37. I've heard, but can't prove that they were used with both the 60 and the 85. It continued in '38 and '39. It looks like Ford was going to use it in '40 but before production started for the '40 but was changed to Model 022A "until stock is used up" according to the EFV8 club's 1938-39 Ford Book.
KGS is offline   Reply With Quote
Old 10-22-2019, 01:46 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
The tube axles were used with both 60 and 85 engines. I have a tube axle that I know was removed from a one-family owned, very low mileage '39 Standard with a V8-60 which was being restored as an 85-horse. I also know first-hand of a '40 Deluxe convertible that came from the factory with
the big V8 and a tube axle. It is NOT true that all V8-60s came with a tube axle. It IS true that some 85s got the tube axles from the factory, all the way through 1940 production. I've never seen any logical rational as to how the tubes were assigned to any certain build. In addition, if you don't have the two proper V8-60 kingpin locking pins with your axle, the standard I-beam lock pins won't work! DD
T5 W/TORQUE TUBE
Old 10-23-2019, 10:34 PM   #7
3738
3738's Avatar
My all original unrestored 37 V8 60 does not have a tube axle. It does have the original aluminum intake and aluminum heads
3738 is offline   Reply With Quote
