Old 09-27-2019, 10:58 AM   #1
grumppyoldman
grumppyoldman's Avatar
Default Rubber seals around doors
my 55 Ford Fairlane has no seals around the doors, should it have them or not. I would think there should be some. Al
grumppyoldman is offline   Reply With Quote
Old 09-27-2019, 11:06 AM   #2
darrell
Default Re: Rubber seals around doors
yes it should have them
darrell is offline   Reply With Quote
Old 09-27-2019, 11:13 AM   #3
grumppyoldman
Disreguard post found them at Steele Rubber gaskets. Al
Old 09-30-2019, 09:52 PM   #4
okiedokie
okiedokie's Avatar
Not fun to install with the doors on the car.
okiedokie is offline   Reply With Quote
Old 10-01-2019, 09:38 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
But it can be done. It is necessary to remove the pin for the door check arms on the back doors and carefully pull the back doors open a little more to thread the gasket thru at that point.
I did it while doors were on the car each time I had to replace gaskets.
Old 10-03-2019, 07:57 AM   #6
bobss396
bobss396's Avatar
I still have 1 side to go on my car. The first I did with the door on the car, but I had a helper. The next one, I will mask off where I don't want the adhesive, saves lots of clean up.
bobss396 is offline   Reply With Quote
Old 10-03-2019, 07:17 PM   #7
Hot Rod Reverend
Hot Rod Reverend's Avatar
you can always do it this way...
Yes, I am married, and Yes, she is awesome!
There is a whole lot more on the build if you visit my personal website... hundreds of graphics, videos, and all the rest concerning the 1955 Ford Fairlane Club Sedan.
Red Lion, Pennsylvania
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 10-04-2019, 09:52 AM   #8
56sedandelivery
56sedandelivery's Avatar
Now THAT is what a living room is supposed to be used for.
56sedandelivery is offline   Reply With Quote
Old 10-10-2019, 01:08 PM   #9
grumppyoldman
thanks for advice and pics. Al
Old 10-10-2019, 07:27 PM   #10
Daves55Sedan
The first time I installed new door gaskets on my '55 Fairlane, I also did it with the doors off like Hotrodrev did, except I didn't use tape. Instead, I took long strips of 1/8" Masonite (I cut from scraps). I used C-Clamps to clamp the Masonite to the gaskets on the backside of the doors and strips of thick cardboard on the outside so that the C-clamp would not mar the paint finish on the outside. I used the long strips of Masonite and cardboard around window frames and at the bottom. At the curved part of the doors along the sides, I used shorter pieces of Masonite.
the glue held very well thru the years. The gaskets did not hold up that long. (Dennis Carpenter shrinking foam rubber). Horrible. I had to end up cutting off the parts around the windows and replacing it with a different product a couple years ago. Used same method to attach as before, except with doors installed on the car.
Old 10-11-2019, 01:29 PM   #11
grumppyoldman
Would you guy's recommend the Steele gasket's for my job? I used them on my 41 and they seemed ok, just got a little messy with the adhesive, and it's hard to clean up. Al
Old 10-11-2019, 02:16 PM   #12
56sedandelivery
What adhesive do you use on these?
