Old 06-07-2019, 12:48 PM   #1
chrs1961815
chrs1961815's Avatar
Question Starter Switch Questions
So I am restoring two starter switches and have a few questions. I have a new old stock switch and I was looking at the hardware on the battery stud. It has a "special" internal lock washer that nobody seems to sell (I don't think). Take a look at these pictures. Under it there is a special nut too. Nobody seems to sell that either. is this original or did somebody replace this with funky hardware? My final question is if the switch was painted black, the threaded rod that has the starter rod thread into was also painted black because it was already mounted right?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-07-2019, 12:51 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Starter Switch Questions
I always thought they were cad plated. Someone with the judging standards will be able to say for sure.
Old 06-07-2019, 01:01 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
Probably aftermarket, not Ford, there were many companies making parts, some made different than original
Old 06-07-2019, 01:07 PM   #4
chrs1961815
According to the JS, they were either black or cad.
Old 06-07-2019, 01:08 PM   #5
chrs1961815
It still has the original Ford Tag with part number "A-11450."
Old 06-07-2019, 01:46 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
A lot of those tags were made in the 70s, I used to put them on flea market parts
Old 06-07-2019, 01:50 PM   #7
chrs1961815
It does look like it has never been used. There is no play in the plunger and no pitting on the contact strip.
Old 06-07-2019, 07:30 PM   #8
jax55
jax55's Avatar
Later ford solenoids used those "speed nuts" to hold the studs in place. My thought was that it would hold the stud in place, but not need a wider nut and longer stud.
They can be unscrewed if you start them with pliers.
Probably an aftermarket version.
jax55 is offline   Reply With Quote
