Old 03-25-2019, 05:29 PM   #1
RocketsGarage
RocketsGarage's Avatar
Default 1955 Ford wagon tail gate seal
I'm wondering what other wagon owners have done about the lower weatherstrip seal retainer? I searched through the junk yard and all the cars that had them where not salvageable. The original from our Ranch wagon is long gone. I'd like to fin an NOS one or something but was wondering if there's other options out there. Thanks
www.RocketsGarage.com
RocketsGarage is offline   Reply With Quote
Old 03-25-2019, 08:51 PM   #2
paul2748
paul2748's Avatar
Default Re: 1955 Ford wagon tail gate seal
There is another member, Poolplayer, that also had a 55 wagon. PM or email him and see if he can help you. Maybe dimensions or a lead. He has a post on this forum, so you can contact him.
If you have any idea of the dimensions of the piece, then a sheet metal shop may be able to make one up.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-25-2019, 09:01 PM   #3
Daves55Sedan
Daves55Sedan's Avatar
My '55 Courier wagon has a back door rather than a tailgate and lift window, BUT, I intentionally left off any seal at the bottom of the door so that the little open slot would relieve some cabin pressure as I went flying down the highway with the driver and passenger door windows open. Water can't get in there anyway unless somehow the laws of physics were defied, allowing rain water to run uphill. Right?
Old 03-25-2019, 09:05 PM   #4
Daves55Sedan
Aside from the tailgate and liftgate gaskets, there is also supposed to be a one-piece rubber gasket that gets glued to the door-jamb of the car body. That gasket only runs along the top and sides, leaving the bottom open. Most of the resto parts suppliers offer that gasket as well as the tail and liftgate gaskets.
Old 03-26-2019, 02:41 PM   #5
RocketsGarage
We've got all the gaskets and modified a few. I was able to source a rusty seal retainer this morning from the wrecking yard. Looks like I might just use it as a basis to fabricate a new one.
Old 03-30-2019, 10:28 AM   #6
poolplayer1
You can get all the seals for your wagon from C&G ford parts. I ordered everything that I needed and it all fit just right. The Lower Tail gate Seal is part # B5A-5941608-D.
There is also an outer seal in that tailgate that I replaced and its part #B5A-7943726-A
Hope this helps. You can go to www.cgfordparts.com and get your weatherstripping.
poolplayer1 is offline   Reply With Quote
Old 04-01-2019, 06:57 PM   #7
RocketsGarage
Ended up fabricating a new one using the rusty one as a pattern
Old 04-01-2019, 08:00 PM   #8
paul2748
paul2748's Avatar
Nice job
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-01-2019, 08:53 PM   #9
Daves55Sedan
That old one looks like you could have knocked all the rust off of it pretty easily using a wire-wheel attached to a bench-grinder. Then coat both sides with acid etch and let dry. Primer and overcoat with enamel, like new. (Unless there are bad weak spots and rust holes). But from the photos, it still looks pretty civil.
Old 04-02-2019, 09:58 PM   #10
RocketsGarage
It had allot of pitting and some large bad rust spots.
Old 04-08-2019, 07:12 PM   #11
datac
datac's Avatar
Speaking of which, anyone know of a source for a rear door seal for a '55 Courier?
datac is offline   Reply With Quote
