Old 03-17-2019, 12:24 PM   #1
Richardtx
Default 40 Ford serial # location... update
Found the serial number. It was way up front on top of front crossmember. It was right next to the two rivets along the very edge of the frame rail. Thanks to all for help.
Richardtx is offline   Reply With Quote
Old 03-17-2019, 12:47 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 40 Ford serial # location... update
On top of the cross member? I've never seen that.
Old 03-17-2019, 12:50 PM   #3
Charlie Stephens
Sounds fishy. Is there any damage to the top of the left frame rail that might have obliterated the original number? Are the numbers the correct font? Do they match the title? How about a picture?
Charlie Stephens
Old 03-17-2019, 12:51 PM   #4
Richardtx
Not on crosmember. On frame rail where the rivets attach to crosmember.
Old 03-17-2019, 12:58 PM   #5
Richardtx
The numbers are clear and match the title.
Old 03-17-2019, 02:56 PM   #6
JSeery
JSeery's Avatar
For some reason the earlier years tend to be near the firewall and then migrate toward the crossmember as the years go by (but can be anywhere in a given year!). What a job, stamping numbers all day every day!!
Old 03-17-2019, 04:16 PM   #7
flatford8
flatford8's Avatar
What a job, stamping numbers all day every day!!......I can imagine some of the conversations on the line...” Hey Fred, is this number 151 or 152 ???”.......Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 03-17-2019, 04:28 PM   #8
Mart
Mart's Avatar
Both of my 41 pus have the number as described above, in line with the front crossmember, near the rivets. if you think about it, it would have been a good solid place to hit, the frame would have more bounce further back.
When I replaced the front crossmember I had to be careful not to damage the area where the number was, it was that close to the rivets.
Mart.
Old 03-17-2019, 06:49 PM   #9
fortyfords
fortyfords's Avatar
That's why I don't like MII front ends, they cover up the number.
fortyfords is offline   Reply With Quote
Old 03-17-2019, 07:42 PM   #10
Kube
Super Moderator
Kube's Avatar
Oh, now I understand. In your earlier post you said
"It was way up front on top of front crossmember".
Old 03-19-2019, 10:17 PM   #11
fortyonerag
fortyonerag's Avatar
Mart.
Same with 41 pass car!
fortyonerag is offline   Reply With Quote
Old 03-20-2019, 11:54 AM   #12
Bob NH
Bob NH's Avatar
Anybody have a clue where they might be found on a 42-47 pickup ? I have the bed off and have sanded both rails to bare metal from back of cab all the way back to the end as well as from radiator to front of cab and find nothing. Do ya think it's possible it never got marked at all ?
Bob NH is offline   Reply With Quote
Old 03-20-2019, 12:07 PM   #13
TJ
TJ's Avatar
Not sure about the 42-47 pickup as they have a different frame. The 48-52 F-1 pickups have the number stamped on top of the right frame rail near the front crossmember. Possibly the 42-47 pickups could be the same?
Old 03-20-2019, 12:24 PM   #14
Krylon32
I've built dozens of IFS 35-40 chassis and I always let the customer take care of re stamping the numbers if needed.
Krylon32 is offline   Reply With Quote
Old 03-20-2019, 12:32 PM   #15
Floyd
passenger cars had number stamped in three places. one on frame rail near firewall or farther forward heading toward the crossmember depending on year. The other two places where considered the "secret" locations" that where father back on the rail, one being on top of the rear wheel arch. These where hidden by the body and used as security checks for stolen vehicles that had the visible front number altered. Removing the body would reveal the security check numbers.The pick up is considered a "commercial car" and was available as cab only cab only which left the top of the frame rail open for every one to see. If the second and third number stamping was provided , it would give away the two "secret" locations . Therefore the frame was not stamped in those two locations on all commercial cars. One way to tell a commercial car frame (besides measuring the thickness) is that it will only have the chassis number stamped in the forward position only. Passenger car frames have it stamped in all three places. Don't tell anyone about the secret locations , as they are Ford trade secrets!
my opinion
Floyd is offline   Reply With Quote
