Old 10-04-2018, 05:37 PM   #1
telmore1964
Default Driver side door lock
Hello, I have a 1930 Model A closed cab pickup I want to add the sliding type door lock to the drivers side door. I have the sliding lock unit on order but can't cannot clearly see how or where exactly it gets installed.
Thanks
-Tom
telmore1964 is offline   Reply With Quote
Old 10-04-2018, 05:46 PM   #2
jax55
jax55's Avatar
Default Re: Driver side door lock
I have a '31 Sport Coupe, but I suspect it is probably the same.
It should be positioned so when locked it will stop the rod from the handle to the latch from moving down (I think). If you look at how that rod works, it will make more sense.
Mine did not have the lock when I got it, but there may be holes already there to mount the lock... I do not recall having to drill holes anyway.
jax55 is offline   Reply With Quote
Old 10-04-2018, 07:09 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
See #4 pictures.
https://www.fordbarn.com/forum/showt...+removal+tudor
Old 10-05-2018, 12:20 PM   #4
Badpuppy
Originally Posted by Tom Wesenberg View Post
The pics seem to have disappeared, Tom. i remember seeing them though, good ones.
Old 10-05-2018, 12:32 PM   #5
Bob C
That's strange, I saw them there yesterday.
Bob
Old 10-05-2018, 11:41 PM   #6
Tom Wesenberg
I just looked, and all 4 pictures are showing.
Old 10-06-2018, 05:32 AM   #7
MickeyT
Send a message via MSN to MickeyT Send a message via Yahoo to MickeyT
It was missing on my '31 CCPU. Just remove the door panel, slip the lock into place and install the two screws. Pretty simple installation. Then you'll need to cut a hole in the door panel and put on the escutcheon and knob. The idea was the driver should not get out of the traffic side so he would lock the drivers door slide across the seat and get out on the passages side. Then lock the passages door from the outside door handle.
MickeyT is offline   Reply With Quote
Old 10-06-2018, 11:06 AM   #8
Badpuppy
Odd. Only the last sentence was there, even after reloading.
