#21 |
A 10,000mAh cellphone charger will run the GPS on your phone all day. Google maps. Cost $20
Ray White |
#22 | |
That really surprises me. I haven't used my CB since the late 70's. |
#23 |
Seems to be a problem loading pics right now, but got one to load, red wire to ground, black to battery, that's all it takes,
No need to spend big bucks on such a simple issue
#24 |
Maybe run the black wire to the terminal box so that the load is reflected on the Amp meter?
#25 |
I stated "black to battery" just to be simple, fact is my connection is aft of the fuse block.
The draw on charging phones, GPS's is so slight I doubt it would read on the meter...but don't let that stop you. Point is, hooking up a USB phone charger to a Model A is so simple and quick. Keep in mind if you have a 6V neg or 12V pos system...wire it accordingly Go for it, you're not going to hurt anything
#26 |
I'm planning on installing a 12v converter to see if that helps. |
#27 | |
Me too. No out of pocket because I already owned these... about $7 for the lead/outlet and a couple more for the USB adapter. Even though you're only putting in 6VDC (instead of the 12 it is marketed for) the little USB adapter modulates to 5.11VDC anyway. Another shade tree innovation but as always... YMMV! 5.11VDC.jpg 12V_outlet.jpg
Cave Luther Syracuse, NY 1931 Deluxe Coupe (Rose) ______________________________________ "... I'm pullin' for ya, we're all in this together." Red Green |
#28 |
Look for "Anyone use a Tom-Tom GPS" that was posted earlier, go down to my reply NUMBER 11, I used a cigarette style lighter plug as the article shows and it works great for my GPS/and cell. Good article. Yes... powered by 6 volts
#29 |
