Old 01-05-2018, 12:32 PM   #1
19Fordy
19Fordy's Avatar
Default Use Caulking Gun to Fill Transmission and Differential
Just thought of this yesterday and thought it might help folks make the messy job of filling your trans. and diff. with gear oil, etc. Also steering box with corn head grease, etc. Works great. You can"squirt" the gun at any angle.
1.Remove the plastic end cap plunger from empty caulking tube and clean out the insides of both nice and clean. I used gasolene.
2. Cut spout so it has a 3/8 in. ID.
3. Screw in 3/8 dia. bolt just a few threads to prevent any leaking.
4. Pour gear oil into cleaned out caulking gun. It holds 15 oz.
5.Insert plastic plunger.
6. Insert cartridge in caulking gun, unscrew bolt and pull the trigger to fill.
7. Remove plastic plunger through the spout with 1/8 dia. rod, wooden dowel or long thin screwdriver.
Empty can was used to support cartridge. Use different cartridges for specific lubricants.
Old 01-05-2018, 12:49 PM   #2
Ron Pilger
Ron Pilger's Avatar
Default Re: Use Caulking Gun to Fill Transmission and Differential
Brilliant and way less messy, and not near as wasteful, than other ideas I have tried. Well done, sir!
Ron Pilger is offline   Reply With Quote
Old 01-05-2018, 01:16 PM   #3
Royal Ryser
I particularly appreciate this kind of thread. 19Fordy gives us a good solution to a problem with pictures and narrative, so that his good idea makes sense to the densest of us.
Thanks for the information.
Royal Ryser is offline   Reply With Quote
Old 01-05-2018, 03:21 PM   #4
Bertha
Bertha's Avatar
Wink Re: Use Caulking Gun to Fill Transmission and Differential
Great idea!!!.....but I see no good use for STP oil treatment.
..."they are only original once"
Bertha is offline   Reply With Quote
Old 01-05-2018, 04:34 PM   #5
oldford2
oldford2's Avatar
Why reinvent the wheel.
I buy a gallon container of gear oil that has a pump and hose/nozzle with it to fit in the filler hole.
oldford2 is offline   Reply With Quote
Old 01-05-2018, 04:47 PM   #6
JimG
JimG's Avatar
I bought a pump from Amazon with my one galloon Stalube GL4 gear oil. It's about $10.
https://www.amazon.com/Custom-Access...9BYWYB97GAH2A4
JimG is offline   Reply With Quote
Old 01-05-2018, 04:55 PM   #7
adileo
adileo's Avatar
Please share more info? Brand and where you purchase?
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 01-05-2018, 04:57 PM   #8
19Fordy
19Fordy's Avatar
I didn't know there was a pump available. I hope it works good as I have never found pumps like those to be long lasting. Mine always break and never reach the bottom of the bottle. Plus, caulking tube is cheap.
Old 01-05-2018, 04:58 PM   #9
zzlegend
zzlegend's Avatar
Yep that's all I use. Have 3 or 4 of them. Used for the last 15 or 20 years.
zzlegend is offline   Reply With Quote
Old 01-05-2018, 05:02 PM   #10
JimG
JimG's Avatar
I posted a URL with the Amazon Link. Click on it to go there. The one I bought is a 36671 Pennzoil Fluid Transfer Pump. I only used it once so far, so I can't say how long it might last. It is all plastic, so not all that sturdy, but you are only pumping a little gear oil.
Old 01-05-2018, 05:02 PM   #11
V12Bill
V12Bill's Avatar
Years ago, I bought a suction/pump device that looks like the caulking gun set up from NAPA. It was probably used in the old days to suck oil out of the oil filter canister as well as filling trans and difs. I would think that they would still be available.
V12Bill is offline   Reply With Quote
Old 01-05-2018, 05:17 PM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
They are still available. I bought one like you mention last year at Advanced Auto, but have not used it yet. I also carry about a one quart bottle with what looks like a simple liquid hand soap pump screwed on top for adding small amounts of gear lube to trans or rear when traveling on tours. Works very well.
A lot of good ideas presented here on this thread.....all good in my opinion.
John
Old 01-05-2018, 06:29 PM   #13
alanwoodieman
I make a 50/50 solution of synthetic gear oil (90wt) and synthetic grease to put into my steering box, u-joint to put it in I use a air powered grease gun--less messy and works good. I like the caulk tube idea, will give it a try
Old 01-05-2018, 07:24 PM   #14
Bertha
Bertha's Avatar
Thumbs up Re: Use Caulking Gun to Fill Transmission and Differential
Mercury Marine
Scroll down for more options
10 yrs of yearly lower unit gear oil changes...SFSG
Bob
Old 01-05-2018, 07:54 PM   #15
34pickup
34pickup's Avatar
I like this idea.
I have one of the pictured pumps and as stated above, it doesn't reach down far enough into the container.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 01-05-2018, 09:44 PM   #16
GB SISSON
GB SISSON's Avatar
Can't wait to try the caulking gun trick. And I have been known to add some stp as well. Thick is good in a crash-box. Thank you for the idea!
Old 01-06-2018, 05:42 AM   #17
Frank Miller
Frank Miller's Avatar
I got one of these at Advance Auto Parts
http://hardwareonlinestore.com/index...hg7f5djqitnahs
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-06-2018, 07:24 AM   #18
dwick01
dwick01's Avatar
Great idea 19Fordy. Thanks for sharing. I am going to make one and give it go.
dwick01 is offline   Reply With Quote
Old 01-06-2018, 08:00 AM   #19
adileo
adileo's Avatar
Anyone know anything about this gallon container? Brand & where to buy?
Thanks
Andy
1952 F1
Old 01-06-2018, 09:22 AM   #20
KGS
KGS's Avatar
NAPA. Gear oil:
https://www.napaonline.com/en/p/SLRSL24239
Gear oil pump;
https://www.google.com/search?tbm=is...=1515248440665
KGS is offline   Reply With Quote
