#21 |
The bodies are bigger on the the MGB ones and the bolt centres are the same as stock A shocks. I normally weld a replacement ball in from the wrong side and use Model B links. But do be careful fitting them to the front as there's not much suspension travel before the track rod hits them.
#22 |
Be aware there are different hole centres I suppose the MGB ones have the same centres as the model A frame . I have several sets of these but have not fitted any yet . I do have some where the mounting hols are further apart which would require frame drilling . These came off English Ford Consul/Zepther/Zodiac so dont buy the wrong ones off Ebay . I seem to think there is a fitting issue for the rears I have seen a 30 fordor where the body wheel arch had to be modifide for the shock to be mounted flush to the frame .
John in cloudy mild Suffolk County England . |
#23 |
I used TR7 shocks on the back of my last A when the originals and repops were unobtanium. They have longer arms and bigger cylinders. Had them rebuilt by Apple Hydraulics.
I'm not napping, I'm testing the couch. |
#24 |
#25 |
Thanks for the info, it is very helpful in figuring this all out.
The Barn group comes through again!! |
