I have sets of used pistons that look very good but would like to confirm how to measure them.
I think I should mike the piston 90 degrees to the pin and bottom of the piston? Very bottom or just below the pin? Seems that the top the piston has always been smaller than the bottom. Thanks for helping me learn. Fourdy |
Super Moderator
Top AND bottom parallel to the pin AND ninety degrees from the pin.
The measurement perpendicular to the pin and about 1/2" above the bottom of the skirt is what is used to determine the bore size for proper clearance. Another very important measure is the width of the ring grooves to be sure they are not too worn.
Flathead Jack is right, The skirt tappered about .002 up. I used to get semmy pistons and grind them any size I needed. Walt
#5 | |
Lonnie Last edited by Binx; 11-14-2017 at 11:32 PM. |
