The Ford Barn
-   -   Measuring pistons? (https://www.fordbarn.com/forum/showthread.php?t=233346)
Fourdy 11-14-2017 02:58 PM
Measuring pistons?
I have sets of used pistons that look very good but would like to confirm how to measure them.
I think I should mike the piston 90 degrees to the pin and bottom of the piston? Very bottom or just below the pin?
Seems that the top the piston has always been smaller than the bottom.
Thanks for helping me learn.
Fourdy
Kube 11-14-2017 03:06 PM
Re: Measuring pistons?
Top AND bottom parallel to the pin AND ninety degrees from the pin.
flatjack9 11-14-2017 06:27 PM
The measurement perpendicular to the pin and about 1/2" above the bottom of the skirt is what is used to determine the bore size for proper clearance. Another very important measure is the width of the ring grooves to be sure they are not too worn.
Walt Dupont--Me. 11-14-2017 06:37 PM
Flathead Jack is right, The skirt tappered about .002 up. I used to get semmy pistons and grind them any size I needed. Walt
Binx 11-14-2017 10:56 PM
Along with measuring, clean the grooves completely with solvent and a stiff bristle brush. Look at the sides of the grooves closely with a magnifying glass or loupe. If you see a step worn in the groove it won't seat new rings.
Lonnie
