#21 |
Where do you find "phosphorics" and what form do they come in?
#22 |
Muratic will attack the metal itself. It will crumble cast iron and put veins in some cold rolled steel alloys. Just my experience. Using it for a short time probably won't do this. To neutralize it, plain water is not sufficient. Make up a bath of water and bicarbonate of soda. It is a "base" and will neutralize the acid. You can see the foaming reaction, just use enough solution until it stops foaming. If the muriatic acid container is leaking you will find rust forming on your machinery in a short time just from the vapors.
Phosphoric acid is better. It takes off the rust but does not attack the steel and it leaves a gray coating that is rust resistant and can be left on for painting. I believe this is what the new car companies use. You can get it in the hardware store labeled as "concrete cleaner and rust remover" and it should show the ingredient as phosphoric acid, not muriatic acid. Both acids are used for concrete etching. Electrolytic is the best though. |
#23 |
I have heard stories about even tightly screwed on caps allowing fumes out and everything else on the shelf and around getting rusty.
#24 |
It's my understanding that muratic acid LOVES chrome, and just minor vapors will destroy nice chrome.
The pursuit of excellence is healthy and rewarding. The pursuit of perfection is frustrating, neurotic and a terrible waste of time. |
#25 |
#26 | |
Job |
#27 |
I glass bead everything looks like new when finished & dose'nt hurt the metal --brass-aluminum--ect steve plucker i'm close --up in dayton if you need anything bead blasted pm me
#28 |
Steve,
If you are going to use that bad stuff, best to neuturalize with Baking soda water solution to stop the action of the acid. Also do not expose any other bare parts to the fumes as they will rust immediately. I quit using Muriatic Acid over 30 years ago. Just my opinion. Ron |
#29 | |
What type of media do you put in the tumbler? Keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. Last edited by jerseyboy; 02-03-2011 at 10:13 PM. Reason: addition |
#30 |
My tumbler is 12" x 12" and 36" long. As it vibrates, it tumbles the media as well as the parts inside over each other. When I first acquired it I took it to a media supplier along with the items that I wanted to tumble. Once there, he displayed an large selection and I chose a media that would fit down inside the teeth on transmission gears to clean the bottom of the grooves. What I ended up with was a ceramic media about 3/16" in diameter by about 1/2" long and they were taper cut at each end. I do not know the name , but they also supplied me with a cleaning agent to dip the parts in when I was done tumbling. After I apply WD40 to the entire part, they will stay corrosion free for as long as a year of more or untill the WD40 needs reapplying.
I also use the phosphoric method of limiting rust on sheet metal parts. Brent Terry showed me that process. I like it because I can go back over it and weld and re-apply it, and it does not interfere with subsequent metal shaping in any way. I prefer to apply it thickly, then right away, wipe it down with a cloth. If I do it that way, I have a consistant smooth finish.
Uncle Bud says "too soon old, too late smart!" |
#31 |
I've had good luck (if your not in a big hurry) degreasing really greasy parts in 50/50 Simple Green HD for up to a week and sometimes longer. http://www.simplegreen.com/products_pro_hd.php. After, wash and scrub with a brass cleaning brush in hot soapy (dish detergent water) until clean. The Simple Grean HD works pretty good. After if lightly rusty soak the parts in the Evapo-Rust. That stuff works really well too.
#32 |
Tom from Drippin mentioned the effect of muriatic on chrome. The quickest way to remove chrome from a part you want to paint is with muriatic and a steel wool pad. It washes off qiock! Besure to use safety glasses and rubber gloves and be sure to neutralize it with the bicarbonate solution before painting.
