What 12v coil with built in resister do I need to convert my 49 flathead?
49merc,
NAPA IC 64 or the Bosch 00012. The Bosch has a funky aluminum case if you are into funky. Charlie ny |
You might also check with Bubba's Ignition. I use his could and they have worked well for me ....
I don't like funky haha. I got a 12v coil and stater solenoid from Vintage Auto garage but I think i burnt it up. Put a meter on it and Ohm 200 +- was 3.4 & 20k center coil was 8.4. Trying to get my motor to start on the frame 2 yrs ago I had it dynoed and broke in it ran good. I also got a napa number off of a tractor site ic145b ? Anyone heard of that one?
I went to Napa and the ic64 is now the ic14.
Anyone know the OHM reading it's supposed to be? |
#6 | |
All I can find with a quick search is: NAPA IC-14 Echlin 3.25 ohms primary resistance Last edited by JSeery; 03-11-2017 at 08:55 PM. |
Thanks. That's what mine is measuring. So I guess I didn't over heat it.
JSeery: Thanks for posting that testing diagram.
I have a 12 volt coil from both Bubba and Charlie NY (a Bosch Blue). IMHO they are both top quality for professional services and parts. My two both test at about 3.4 ohms. Last edited by Drbrown; 03-11-2017 at 11:55 PM. |
