Old 12-11-2016, 01:10 AM   #1
[email protected]
Default Remove V8 oil pan on a '37 Ford Sedan
Is it possible to remove a V8 oil pan from a '37 Ford Sedan while the motor is in the car? I have all the pan and appropriate transmission bolts out, the the starter is removed as is the wishbone. The pan is loose and I've jacked the motor up as far as it will go (breather hits the firewall) and I can't clear the front crossmember and the crank counterweight to get it out. Are there any tricks? I hate the thought of pulling the motor to change a leaky front seal. Thanks.
clawson28@gmail.com is offline   Reply With Quote
Old 12-11-2016, 01:31 AM   #2
Brian
Brian's Avatar
Default Re: Remove V8 oil pan on a '37 Ford Sedan
Rotate the crankshaft.
Old 12-11-2016, 02:18 AM   #3
Flatout
Flatout's Avatar
I did it on my 37 in 1964.
Jack up the car by the frame so that the front suspension hangs down.
Jack up the engine.
It will come off by dropping and rotating it.
Flatout is offline   Reply With Quote
Old 12-11-2016, 01:51 PM   #4
my4dv8
I did remove the pan in our 37 coupe back in the 80s. It was a mission but came out. Don't think it matters but our motor was a 99a.
my4dv8 is offline   Reply With Quote
Old 12-11-2016, 08:08 PM   #5
Brendan
Brendan's Avatar
remove the breather, and anything that will prevent you from getting the motor up as high as you can
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
