Old 07-17-2016, 04:44 PM   #1
Jakno
Jakno's Avatar
Default 35 pickup floorboards
ready to install the floorboards in my 35 pickup 1/2 ton. Not sure if I have all the correct parts. The wood floor piece fits ok as well as the metal toe board to the firewall. There is a space open around the clutch & brake pedals that look like they could use another part. The transmission cover in the photo doesn't look like it the correct one. FYI the parts are just laid in and not bolted down. Any thoughts would be appreciated.... Thanks
Lineman, the only dumb animal that can harness himself !!
Jakno is offline   Reply With Quote
Old 07-17-2016, 04:59 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 35 pickup floorboards
Had you noticed this pic of the floor in Vanspeed's '35? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-17-2016, 05:01 PM   #3
Jakno
Jakno's Avatar
Just found those pictures after I pushed "submit" on my post. The pictures are perfect for what I need. Thanks for taking the time to respond.
Old 07-17-2016, 07:44 PM   #4
Don Rogers
Don Rogers's Avatar
Janko, Here are some images showing the pedal plate and a comparison of a 35 and 36 trans cover.
Don Rogers is offline   Reply With Quote
Old 07-18-2016, 06:42 AM   #5
oldandtired
Jakno...The 35 pickup toeboard in the picture has some holes added in the left lower corner area. The un-modified toeboard does not have those. Perhaps someone over the years moved the starter switch or added a dimmer switch to the floorboard. Perhaps they are out of the picture, but I also do not see the battery access in the wooden floorboard.
oldandtired is offline   Reply With Quote
Old 07-18-2016, 05:11 PM   #6
Jakno
Jakno's Avatar
Oldandtired, the battery has been moved to the truck bed. I think with the info I have from you folks what I have will make up my floorboards. Thanks for the help
