Old 04-23-2016, 12:11 PM   #1
cowtown
Default Ttransmission removel from F1 HELP!
I am getting ready to remove my 4 speed tranny and install a newly rebuilt 3 speed top loader along with clutch and everything that goes along with it in my 50 F1. I just put it up on jack stands and ready to start. My question is that it doesn't look like there is enough room to slide the 4 speed tranny back from the engine because of the cross member sitting so close. Am I missing something ????
cowtown is offline   Reply With Quote
Old 04-23-2016, 12:31 PM   #2
JSeery
JSeery's Avatar
Default Re: Ttransmission removel from F1 HELP!
Per the manual it can be removed.
Hoist vehicle and drain lubricant.
Remove Seat cushion and floor plate
Place support under the rear of the engine
Disconnect drive shaft
Remove any linkage connected to transmission
Disconnect clutch equalizer shaft
Disconnect speedometer cable
Disconnect transmission at engine rear support and at the bellhousing
Pull transmission the rear until spline shaft is clear of the clutch
Lift transmission through the opening in the floor.
I've never done it, that is just from the manual!
Old 04-23-2016, 12:42 PM   #3
cowtown
I have the manual and read the same thing. But I just measured it and there is only 3/4" of a inch between the rear of the tranny and the cross member. Got to go back farther than that. Doesn't It?
Old 04-23-2016, 12:44 PM   #4
JSeery
JSeery's Avatar
Yep it would need the thickness of the pressure plate plus the distance from the flywheel surface to the front side of the pilot bearing, darn that manual! Maybe someone with some actual experience will jump on before long!
Old 04-23-2016, 01:06 PM   #5
estout81
Jack up the rear of engine.
estout81 is offline   Reply With Quote
Old 04-23-2016, 04:03 PM   #6
gearhead1952
gearhead1952's Avatar
Those 4 speeds are heavy. I could not imagine trying to pull one out of the trans opening. Probably want to take the seat out if you try it. If your truck is all painted up would be another reason not try it. Not much room at the rear between trans and crossmember.
gearhead1952 is offline   Reply With Quote
Old 04-23-2016, 04:07 PM   #7
cowtown
Got the seat out and going to pull with engine hoist.
Old 04-23-2016, 04:11 PM   #8
Ianrhall
I just did mine, got the box out(just) but to reinstall I had to remove the crescent shaped mounting from the crossmember, would have been "much" easier had I removed that first!
Ianrhall is offline   Reply With Quote
Old 04-23-2016, 06:07 PM   #9
Charlie ny
I 'done' that job.........4spd out thru cab. I yanked a nonsyncro from a '51 F1 and installed a side shift......the job seemed as though it would never end. As you know the 4 spd driveshaft and the 3 spd driveshaft are way not the same.
Charlie ny
Old 04-23-2016, 07:46 PM   #10
cowtown
Default Re: Transmission removel from F1 HELP!
Yep Got the right drive shaft and its ready to go. Any other tips on getting the 4 speed out of the truck? Hope to get it out tomorrow.
Old 04-23-2016, 07:58 PM   #11
35fordtn
35fordtn's Avatar
I have done that conversion on a truck I had a few years ago. Be ready for severe back pain the next week after!! If I recall I jacked the rear of the engine removed the mount and it narrowly came out. Much easier with two people.
Old 04-24-2016, 03:22 PM   #12
Ford Freak
^^What 35ford said^^ You have to jack up the rear of the engine , and it will just clear . And , make sure you have a helper !
Ford Freak is offline   Reply With Quote
Old 04-24-2016, 05:48 PM   #13
Ken Crans
Ken Crans's Avatar
Got that done yet?? lol Its a pain!
Ken Crans is offline   Reply With Quote
Old 04-24-2016, 06:04 PM   #14
Ross F-1
Ross F-1's Avatar
Disconnect exhaust pipe(s)
Disconnect lower radiator hoses
Loosen (don't remove) front motor mounts
Pull starter and starter plate
Raise engine by jacking at rear of pan until trans "ears" clear rear support
Lift transmission with a cherry pickerthrough the opening in the floor from the passenger door opening.
Done this more times than I care to tell.... at least with the LD trans you can just reach down and pick it up.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-25-2016, 06:51 AM   #15
cowtown
Got it ready to come out but need to bring home cherry picker from storage and it was raining all day yesterday. So Hopefully today will get it out. I will keep you informed. Thanks for all the help!
Old 04-25-2016, 12:38 PM   #16
Ianrhall
Cherry picker!! 2 people can lift it out fairly easily
Old 04-25-2016, 12:47 PM   #17
Ross F-1
Ross F-1's Avatar
Originally Posted by Ianrhall View Post
Cherry picker!! 2 young people with strong backs can lift it out fairly easily
Fixed it for you! The 4-sp weighs just over a hundred pounds. Not a lot of room in the cab, even with the seat out. It's likely greasy and not much to grab onto.
Old 04-25-2016, 04:27 PM   #18
cowtown
Got it out by myself with the picker! What a job and no room for error! Hope the new one goes in easier. Going to go and drop off fly wheel at machine shop. No Way will I do this again. I am getting to old for this much work.
Old 04-25-2016, 04:46 PM   #19
JSeery
JSeery's Avatar
Good thinking!
Old 04-26-2016, 04:12 PM   #20
DD931
DD931's Avatar
When I did this swap a few years ago my brother and I manhandled the four speed out. I don't remember it being all that horrible!! The three speed is noticeably lighter, of course, but two people make it much much easier. Take the time to line up the clutch disk properly with an alignment tool so that the tranny will slip in easily. When you're all done you'll think you have a new truck!! Such an improvement in drivability!!
DD931 is offline   Reply With Quote
