Old 04-17-2016, 04:53 PM   #1
charles in east texas
charles in east texas's Avatar
Default 1953 Ford electric clock
How do you remove the working mechanism from the case?
Is there a clock man you would recommend?
Thanks,
Charles In East Texas
charles in east texas is offline   Reply With Quote
Old 04-17-2016, 11:06 PM   #2
fordor41
fordor41's Avatar
Default Re: 1953 Ford electric clock
I disassembled the clock in my '41. Just did some careful prying. Mine was crimped together at the edges in a few spots
fordor41 is offline   Reply With Quote
Old 04-18-2016, 08:00 AM   #3
This clock has an electrical stud at the back. I tried to unscrew
it but would not turn with medium force. It sure appears
that this stud has to come off or out to remove the clock
from the case. Thanks for your reply. Charles
Old 04-18-2016, 07:50 PM   #4
paul2748
paul2748's Avatar
I used Williamson's for the clocks in my 54 Ford and my 56 Bird. I had them do a quartz conversion on both. The 54 was dome about 13 years ago and it's running great. The bird was done about 9 years ago and its running great.
www.williamsons.com
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 04-19-2016, 12:50 PM   #5
I finally got the 53 clock out of the case. I took both nuts off the back and push on the electrical post and after prying up on the tabs against the case the mechanism came lose
of the case. Charles
Old 04-20-2016, 05:10 PM   #6
Finally sent the clock to Williamson's Instruments in Arkanas. Charles
