Old 04-03-2016, 10:41 AM   #1
saltracer
Default chassis dyno results
final results 176 hp, 200 tq. Not street friendly, but really set up for supercharger (eventually). Single Holley 600 cfm, very old Edelbrock intake, Edelbrock heads for supercharger, relieved block, 1.6 valves, Isky single springs, Schnieder cam for supercharger 284-F .433 lift, kinda heavy Arias
3 3/8 pistons for 10 lb of boost, 4" Merc crank and French 6 7/8 rods to use Ford pistons with Merc crank.
saltracer is offline   Reply With Quote
Old 04-03-2016, 10:53 AM   #2
19ED30
19ED30's Avatar
Default Re: chassis dyno results
What body typ?
19ED30 is offline   Reply With Quote
Old 04-03-2016, 10:59 AM   #3
saltracer
1985 Mustang, to run XF/GALT at Wilmington, Ohio. It is a ECTA event, one mile timed. Hopefully we will later add the supercharger and run XF/BGALT also.We also run at Bonneville, hold the record for XF/BGALT.
Old 04-03-2016, 11:16 AM   #4
Ol' Ron
Ol' Ron's Avatar
Delete
Old 04-03-2016, 11:28 AM   #5
sidevalve8ba
sidevalve8ba's Avatar
You have a flathead in a Mustang body? Pictures please. This I gotta see!
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 04-03-2016, 11:32 AM   #6
Kahuna
Kahuna's Avatar
Rpm levels?
Kahuna is offline   Reply With Quote
Old 04-03-2016, 11:51 AM   #7
saltracer
Originally Posted by Ol' Ron View Post
Delete
I'm hurt, Ron. I do plan on running this combination in our '32 Roadster later if that makes up for anything.
Old 04-03-2016, 11:52 AM   #8
saltracer
Originally Posted by Kahuna View Post
Rpm levels?
that one run at 176 hp we stopped at 5k, sometimes shifted at 6k
Old 04-03-2016, 01:50 PM   #9
Ol' Ron
Ol' Ron's Avatar
Saultracer. I didn't mean anything with the NM. I just mis understood your post. In any case 175 hP on a chassis dyno is over 200 on an engine dyno. Pretty stout engine. I'm building a track engine (276), looking for 200 HP with some new ideas. But, I don't think anyone has ever done that on reg gas un blown. Have a friend that has an engine I worked on, that got 235 on gas,#5 boost @ 4500 (red line) but had 300 ft lbs torque @ 3K. The power is out there, but nobody has found it yet. Been allot of clamers tho.
Old 04-03-2016, 04:02 PM   #10
19ED30
19ED30's Avatar
85 mustang !!!
You could get 210 hp pretty much stock with tuning ,,
Old 04-03-2016, 04:06 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 19ED30 View Post
85 mustang !!!
Might as well be comparing apples with celery. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-03-2016, 04:23 PM   #12
saltracer
85 mustang !!!
no,no we have the 1950 Merc flathead in a 1985 Mustang body so we can run a certain class. Our competition at Bonneville runs a flathead motor in a Nissan 240 SX.
Old 04-03-2016, 04:25 PM   #13
V8COOPMAN
V8COOPMAN's Avatar
NOW we're talkin'! DD
T5 W/TORQUE TUBE
Old 04-03-2016, 07:30 PM   #14
texas webb
I'd like to see both of those!Must be a sight.
texas webb is offline   Reply With Quote
Old 04-03-2016, 07:48 PM   #15
Ronnieroadster
Ronnieroadster's Avatar
Phil you have them guessing
Old 04-03-2016, 08:45 PM   #16
Ol' Ron
Ol' Ron's Avatar
I saw a flatty in a Ford Probe. Now that was slippery.
Old 04-03-2016, 08:51 PM   #17
saltracer
this is our car
Old 04-03-2016, 09:19 PM   #18
tubman
tubman's Avatar
Sounds impressive. I guess this means I won't get 150 HP by putting "carbs 'n heads" on my stock 239! Damn!
Old 04-03-2016, 09:22 PM   #19
Ross F-1
Ross F-1's Avatar
Put a K&N air filter on it, they're worth 10 HP according to the ads.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-03-2016, 10:02 PM   #20
saltracer
this is the engine in Terry Fisher's record setting Nissan 240SX.
