Old 02-29-2016, 10:20 PM   #1
fftoddster
fftoddster's Avatar
Default welch plug 21 stud engine.
I know the welch plug at the bottom of the block is 3/4". The trouble I am having is getting it to seal good because there is some corrosion in this area. I have tried sealant but think it is still weeping.
Does anyone know or have a block available to measure what the inside diameter of the bore is that the 3/4" welch plug goes up against?
I am thinking of trying to find a freeze plug that will fit up in there and then back it up with the 3/4" welch plug with sealant.
Is it 5/8" ? I do not and will not have access to it for several days and I would like to start hunting down a plug to fit it.
Thanks
Todd
fftoddster is offline   Reply With Quote
Old 02-29-2016, 10:41 PM   #2
Mark's 37
Mark's 37's Avatar
Default Re: welch plug 21 stud engine.
Thanks
Todd
Todd, once the plug is in hole you need to whack it in the center with a ball peen hammer, etc, to spread it to fit. I used Permatex "The Right Stuff" to help seal it. Hope that helps you.
Mark's 37 is offline   Reply With Quote
Old 02-29-2016, 11:11 PM   #3
RalphM
RalphM's Avatar
Another possibility is tapping the hole, closest NPT without going to big. Seal the plug with a quality sealer, then machine or file it down so pan gasket seals.
I've done this before on motor that's still running strong.
RalphM is offline   Reply With Quote
Old 02-29-2016, 11:16 PM   #4
Jay in Mass
I used nice copper pennies with some sealer and there are no leaks.
Jay in Mass is offline   Reply With Quote
Old 02-29-2016, 11:32 PM   #5
RalphM
RalphM's Avatar
Forgot to say, use a brass plug, much easier to file down.
Old 02-29-2016, 11:48 PM   #6
fftoddster
fftoddster's Avatar
Yes I understand that and have done that. The problem is that the car sat for 30 years and the corrosion of the weeping welch plug ate away at the surrounding block area. Also ate a hole in the oil pan but I welded that up.
The area just above where the welch plug sits appeared to be in good condition, so If I figure out what size that bore that is I believe a cup style freeze plug would fit and seal nicely there.
Old 03-01-2016, 12:30 AM   #7
Mark's 37
Mark's 37's Avatar
I would be a little concerned that the corrosion has weakened or eaten further into the pan rail, especially on the inner and outer wall margins. Without seeing it it's hard to say but doing a little "dental" work to clear out the cancer to bare metal and see what's what. If that is ok and you think it could be drilled and tapped for a threaded NPT brass plug with thread sealer and filed down as RalphM suggested would be a good choice.
Old 03-01-2016, 12:39 AM   #8
fftoddster
fftoddster's Avatar
No inside the engine actually looks pretty good. It was just the little area outside of area where the welch plug sits outwards.
Old 03-01-2016, 01:12 AM   #9
Mark's 37
Mark's 37's Avatar
I have a 37 engine with the pan off on the engine stand. I will pop one of the plugs out tomorrow and see if I can size the hole.
Old 03-01-2016, 01:20 AM   #10
fftoddster
fftoddster's Avatar
Thanks that would help a lot.
Old 03-01-2016, 01:34 AM   #11
Gary Duff
All of the blocks that I rebuild with those plugs, get drilled and tapped for 1/2 pipe
thread. I remove the center main studs or bolts and drill with magnetic mount drill.
After drilling chuck up a large center drill to start the tap. Use flush pipe plugs and
565 Loctite to finish the job. Gary
Gary Duff is offline   Reply With Quote
Old 03-01-2016, 01:30 PM   #12
Mark's 37
Mark's 37's Avatar
Todd, the hole below the seat step for the 3/4" welch plug on mine is 5/8" ID. If yours hasn't been corroded beyond usefulness, a freeze plug might be the way to go with some sealant. If not, it could be possible to tap it to next NPT size up and use a flush top brass threaded pipe plug.
Old 03-01-2016, 07:12 PM   #13
fftoddster
fftoddster's Avatar
Mark,
Thank you. That is exactly what I was looking for. I remember looking inside on mine and thinking boy that is in really good shape in there. The corrosion and pitting were only on the outer part of the block right where the welch plug was supposed to seal.
Todd
Old 03-01-2016, 09:28 PM   #14
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Sometimes those shoulders are about eaten out inside the hole, clean the hole out and use 3/4 cup plugs instead dish plugs, smear some RTV in the hole, drive the plug in, fill the plug with RTV. Don't forget the install the pan before you pour the oil in. LOL Walt
Old 03-08-2016, 08:44 PM   #15
fftoddster
fftoddster's Avatar
An 11/16" cup freeze plug fit perfectly in the bore right above the 3/4" welch plug landing.
