welch plug 21 stud engine. I know the welch plug at the bottom of the block is 3/4". The trouble I am having is getting it to seal good because there is some corrosion in this area. I have tried sealant but think it is still weeping.
Does anyone know or have a block available to measure what the inside diameter of the bore is that the 3/4" welch plug goes up against? I am thinking of trying to find a freeze plug that will fit up in there and then back it up with the 3/4" welch plug with sealant. Is it 5/8" ? I do not and will not have access to it for several days and I would like to start hunting down a plug to fit it. Thanks Todd |
Re: welch plug 21 stud engine. Quote:
Re: welch plug 21 stud engine. Another possibility is tapping the hole, closest NPT without going to big. Seal the plug with a quality sealer, then machine or file it down so pan gasket seals.
I've done this before on motor that's still running strong. |
Re: welch plug 21 stud engine. I used nice copper pennies with some sealer and there are no leaks.
Re: welch plug 21 stud engine. Forgot to say, use a brass plug, much easier to file down.
Yes I understand that and have done that. The problem is that the car sat for 30 years and the corrosion of the weeping welch plug ate away at the surrounding block area. Also ate a hole in the oil pan but I welded that up. The area just above where the welch plug sits appeared to be in good condition, so If I figure out what size that bore that is I believe a cup style freeze plug would fit and seal nicely there. |
Re: welch plug 21 stud engine. No inside the engine actually looks pretty good. It was just the little area outside of area where the welch plug sits outwards.
Re: welch plug 21 stud engine. All of the blocks that I rebuild with those plugs, get drilled and tapped for 1/2 pipe
thread. I remove the center main studs or bolts and drill with magnetic mount drill. After drilling chuck up a large center drill to start the tap. Use flush pipe plugs and 565 Loctite to finish the job. Gary |
Re: welch plug 21 stud engine. 1 Attachment(s)
Mark, Thank you. That is exactly what I was looking for. I remember looking inside on mine and thinking boy that is in really good shape in there. The corrosion and pitting were only on the outer part of the block right where the welch plug was supposed to seal. Todd |
Re: welch plug 21 stud engine. Sometimes those shoulders are about eaten out inside the hole, clean the hole out and use 3/4 cup plugs instead dish plugs, smear some RTV in the hole, drive the plug in, fill the plug with RTV. Don't forget the install the pan before you pour the oil in. LOL Walt
Re: welch plug 21 stud engine. An 11/16" cup freeze plug fit perfectly in the bore right above the 3/4" welch plug landing.
| All times are GMT -5. The time now is 06:00 PM. |
