Old 11-15-2015, 09:56 PM   #1
charles in east texas
charles in east texas's Avatar
Default Gas cut off valve
Is the gas cut off valve supposed to have a spring in it and if so where can I purchase one. Bratton does no carry this spring. I am having a time trying to get this one to quit leaking. Charles
charles in east texas is offline   Reply With Quote
Old 11-15-2015, 10:11 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Gas cut off valve
Try your hardware store for many different springs.
Old 11-15-2015, 11:13 PM   #3
700rpm
700rpm's Avatar
Have you tried to reseat the valve? I used some polishing compound and finished up with toothpaste on mine, and it sealed up fine.
Ray Horton, Portland, OR
Old 11-15-2015, 11:16 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I did the same and have had no leaks since doing it 20 years ago.
For the spring you can also cut down a longer spring and grind the cut end flat.
Old 11-15-2015, 11:18 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
I know it's been a while since I rebuilt mine but I don't remember any spring.
I took it apart, applied some while toothpaste and chucked the movable part in a cordless drill and spun it in the body at a low speed until polished.
