Old 06-29-2015, 01:00 PM   #1
Baker"A"
Default New owner of 1929 model A
Hello all
I was just given my father in laws 1929 Model A. My wife is thrilled. Still trying to get her started! The car not the wife, joined the forum to gather informTion and hopefully assist others as I learn,
Jonathon in Michigan
Baker"A" is offline   Reply With Quote
Old 06-29-2015, 01:06 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: New owner of 1929 model A
Always make sure the Spark Advance Lever is in the Full up position when starting. It's the lever on the left side of steering wheel.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 06-29-2015, 01:17 PM   #3
Russell in Tulsa
Welcome. You sure found the right site to ask and receive help from these guys and gals for anything "A" related. Good luck and be sure to use the "SEARCH" feature at the top of the page.
Russell
Russell in Tulsa is offline   Reply With Quote
Old 06-29-2015, 01:24 PM   #4
roblesterjr04
Spark lever (left) all the way up.
Throttle lever (right) down about 1/4-1/3
Gas valve on (under dash)
Key on
Press starter
Pull/push choke until it starts.
Pull spark down a little and listen to her purrrrrr
-Rob
1929 Fordor Leatherback
roblesterjr04 is offline   Reply With Quote
Old 06-29-2015, 01:24 PM   #5
roblesterjr04
When was the last time it's been started?
-Rob
Old 06-29-2015, 01:49 PM   #6
30ccpickup
30ccpickup's Avatar
Like everything else it is simple once known. Here is the basics to start assuming it is a running car. http://modelabasics.com/Starting%20&%20Driving.htm
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 06-29-2015, 06:54 PM   #7
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
I'd only pull the choke out for one or two chugs or you'll be flooding that puppy and never get it going. Lightly file or sand the points to make sure crud hasn't built up.
Rusty Homestead Fl is offline   Reply With Quote
Old 06-29-2015, 07:01 PM   #8
1930artdeco
1930artdeco's Avatar
If it has been a long time since it was started-like years. the you may want to drop the pan to verify there is no sludge, dirt etc. in the pan. Then add oil adjust the timing if it is off, check the points and plugs and fire her up. Remember, never throw anything away, join a club and drive the wheels off her.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-29-2015, 11:18 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Welcome!!
What have you tried?
What is it doing, not doing?
Old 07-01-2015, 01:11 PM   #10
burner31
burner31's Avatar
How about a picture of the gift.
We all love seeing Model A's, we don't why, it must be a sickness, but none of us are looking for the cure
Keith
Shawnee OK
'31 SW 160-B
Old 07-01-2015, 01:32 PM   #11
mshmodela
mshmodela's Avatar
DITTO! don't over chock... you'll learn like I did that leads to flooding the car...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
